Hmmm - I'll take it from the top. Unplug the deck from the mains while you do this.
The black balance weight is a push fit onto a chrome bushing. It's
anchored there by a ball bearing - twist (to un-anchor it) and pull to
remove it, push and twist to replace it. The chrome bushing has two
screws to lock it down - you'll need a jewellers screwdriver to loosen
them. To move the weight loosen the screws and slide the whole
bushing/weight assembly.
At the base of the gimbal is a tiny wire clip - one end of the spring
hooks onto this, the other end of the spring hooks onto the black
slider. To balance the arm unhook the spring from the slider (you'll
need needle-nose pliers to do this) and put the slider at the "1" line.
The cartridge should be fitted. Unclip the tonearm from its rest and
lower the cueing lever to free the tonearm - make sure the stylus
doesn't land on anything. Move the balance weight until the tonearm
floats horizontally. Clip the tonearm back and tighten the screws on
the chrome bushing.
Route the spring under the cueing support (check out the pictures of
the pickup arm on the Beoworld products section for reference) and hook
it back onto the black slider (you'll
really need needle-nose pliers to do this!) Now move the slider up to the "2" line. All done.
While we're here, pop a record onto the deck and swing the arm over it.
With the cartridge over the record, check by eye that it is horizontal.
If not, there's a screw under the arm that, when loosened, will allow
the cartridge socket to rotate a bit. It'll be tight so be careful.
And, finally, the base of the cartridge should be about half a cm above
the record when the cueing lever is up. There's a screw right at the
base of the gimbal that, when loosened, allows the height of the gimbal
to be adjusted. If you have to do this, you'll also have to do
something similar with the arm rest to match the new height.
I think that's about it. The tracking force depends on the spring - if
it's tired out or damaged then the numbers you set the slider to will
mean diddly-squat, so adjust any further by trial and error.
Cheers,
Steve
