Latest post 08-06-2011 6:38 PM by mjmedlo. 15 replies.
Page 1 of 1 (16 items)
  • 07-17-2011 12:59 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    Wireless adapter
    Has anyone used a wireless adapter in to the USB port for transferrin music and gettin the n.radio?
    I'm wondering If there's a simple plug n play option without much hassle..
    MJM
    I'm ready for something new that I actually want to buy!
  • 07-17-2011 3:54 PM In reply to
    Re: Wireless adapter
    I am not sure if this answers your question, but I have my Beosound 5 connected to an Airport Express.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 07-17-2011 11:33 PM In reply to
    Yes,
    I use a D-Link USB Wifi adapter. Simply rip your installation CD/drivers to a pendrive, go to maintenance mode (add mouse and Keyboard where needed), in XP, install software like any other PC, then install hardware. Log in your routers code and simples!. Reboot/Exit maintenance mode and it should all work automatically.
    10
  • 07-18-2011 7:36 AM In reply to
    With Airport Express all I had to do was connect it.
  • 07-18-2011 11:08 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Connected it and got n. Music, etc?
  • 07-19-2011 7:59 AM In reply to
    Correct. I can load music on to it wirelessly using both Beoconnect on my iMac and using Beoplayer on a Windows laptop. N. Radio works. Also can stream music from it to iPad and use iPad to control the Beosound with the most recent software update. In other words, all works just as it should.
  • 07-21-2011 7:29 AM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    or you can use this one:
    http://www.asus.com/Networks/WiFi_Networking/WL330gE/
    I'm using it without any problems on my Beosound 5.
  • 07-22-2011 1:34 AM In reply to
    • ECF
    • Not Ranked
    • Joined on 03-28-2009
    • Posts 17
    Just wondering how you connected it (what kind of cable etc) and to which port on the Beomasyer 5?
  • 07-22-2011 7:39 AM In reply to
    I plugged the Airport Express into an electrical outlet and the cable that came with the Airport Express plugs int the Beomaster. Did not need to buy anything other than the Airport Express.
  • 07-22-2011 10:02 AM In reply to
    • ECF
    • Not Ranked
    • Posts 17
    I also have an airport express but it It not come with any cabels. What kind of cable did you use and where did you connect it in the beomaster 5?
  • 07-22-2011 1:19 PM In reply to
    Sorry. My mistake about the cable. It is an ethernet cab the from the Airport Express to the ethernet cable connection on the Beomaster.
  • 07-22-2011 2:58 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    yep, same with the Asus: just an ethernet cable from the Beomaster 5 to the adapter (ok, and a powersupply) ;-)
  • 07-24-2011 12:45 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    I also use Apple to connect my BM5.  I use an Airport Extreme so I can direct connect for big transfers (the Extreme has multiple ethernet ports) - although I haven't really used this much (I did use it when I transferred my main library).  Airport Express can be used with non-Apple wireless routers, but I forget whether or not it was easy to setup (a few years ago, I had a link-sys router, and I did have it working with an AE, but I don't remember if it was as easy as plug-in and it works).
    Any wireless bridge will work - you can find them for ~1/2 the cost of an Airport Express, but since the AE is only ~$100, that's not a huge amount of money.  BM5 thinks it is directly connected to Ethernet (because it is).  Wireless is provided by the bridge.
    Assuming you don't mind the extra box (and have an open power outlet), this is superior to using a wifi usb plug because the BM5 can go into standby mode.  I believe I read that with the usb wifi the BM5 must stay powered on.
    Stan
  • 07-24-2011 5:50 PM In reply to
    Stan:
    I once setup ours up as a bridge with a NETGEAR wireless/modem/router; if you have a Mac you use its Airport Utility to configure so you can name the port ("lounge" etc) and secure it with a password
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 08-03-2011 1:07 AM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Many thanks!
    I will go with an airport express as my set up is all Mac.
    MJM
  • 08-06-2011 6:38 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Picked up the airport express...
    Working great.
    Many thanks!!
