1st March February 2012
Latest post 07-19-2011 3:47 PM by Ulf. 18 replies.
07-14-2011 4:32 PM
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
and again... LOL !!
Dillen
- Copenhagen / Denmark
- Posts 5,008
Ridiculous. I wonder what the price was new. It's used now so will need deactivating and getting used to the new surroundings and owner.
If I use it for the light in my fishtank, will the fish look more real ?
9 LEE
- Moderator - UK
- Posts 5,223
Dillen:
I do hope that was sarcasm..
Dillen
- Posts 5,008
9 LEE:
Dillen:
Why ? Did you actually consider buying it ?
The new owner will obviously have to ship it back to the producer before showing it its new setup. They will then inspect it, demagnetize the copper and vaccuum out any debris and other remains left inside by the previous owners mains. This is particularly important if the cable has been used with coal produced electricity and/or in areas with high winds and a long distance to the nearest transformer station. In most cases, they will also polish out any surface marks on the side of the insulation that faces the copper to give the electrons a cleaner and smoother ride. The screws will also be tightened and if any of the gold plating on the threading is found to be below a certain minimum thickness, the affected screw(s) will be replaced. With all new screws and a proper burn-in time, you won't believe your ears.
I recently heard of a situation where a new owner couldn't make one of these cables sound right. He returned it and upon close inspection it was found out that one of the factory workers had accidentally used DC solder instead of AC. Bummer.
One thing I don't understand though, is how they can make the same cable work equally good in 50 and 60 Hz areas ?
psand
- Joined on 05-05-2010
- Stockholm, Sweden
- Posts 48
Dillen:
I managed to dig up some marketing blurb and a list price of £1,195 for the 1.5 meter cable. The part on experimenting with revised internal wiring configurations is quite funny:
“The Chord Sarum Power Cable uses gold plated Furutech connectors. The engineers were able to experiment extensively with different types of connectors and wiring configurations, in the listening tests Chord decided that the build quality of the Furatech was consistently better and was extremely impressed with the overall build quality.
The engineers were able to experiment with revised internal wiring configurations on the plug itself, which is not possible within a conventional mains plug.
Available in 3 standard lengths of 1 metre, 1.5 metre and 2 metre with the option to add additional metres upon request.
Every Sarum cable is hand made and uses silver plated multi strand oxygen free copper in order to provide the very best in signal without any loss or interference.
But is not just about the cable itself, each strand of the Sarum cable has been precision polished to ensure a microscopically smooth surface before being plated with a heavy layer of silver.
With Teflon insulation, its widely acknowledged as being the best dielectric material to use in order to offer the very finest insulation from surrounding cables or shields.”
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Dillen:One thing I don't understand though, is how they can make the same cable work equally good in 50 and 60 Hz areas ?
These cables are made for 50 Hz only, in 60Hz areas they will only work at riptide and full moon.
The 60Hz version is a black cable with white jacks, as it handles 20% more HZ it cost nearly the double because of thicker gold plating and reverse spun copper leads.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
9 LEE
- Moderator - UK
- Posts 5,223
Søren Mexico:
I found someone who was actually impressed by all that... !!
Dillen
- Posts 5,008
 Curl up the excess length of that cable and you can see its nice properties fly out the window. It will only work properly if kept strictly straight.
Well at least they've got the last meter or two covered fairly alright but I wonder if they ever thought about the inwall wiring, the quality of the outlets, switches, fuseboxes, meters and the rest of the 20 Km cable length from the power-station with all its connections, splicings and transformers, let alone what goes on inside the amplifier or whatever it feeds.
Oxygen-free copper. Bah. Truth is that copper is actually a fairly bad conductor unless used supercold. Any cheap multimeter will easily tell its resistance, oxygen-free or not.
I'm impressed too. Mainly that some people actually buy those cables. I think, I will start producing something similar. My biggest problem would be to stop laughing.
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Just needs connecting to THIS & away you go.
Søren Mexico
- Mexico city
- Posts 1,621
Step1:
I want to know if the company offers the teflon tape modification as an optional extra, or is that the super deluxe version..?
Most AC connection hardware is designed for reliable and safe operation,
not for minimum susceptibility to audio system vibrations. Stiff
springs will have strong acoustic resonances. The Teflon tape tweak
provides a safe and benign material to dampen the acoustic resonances
built in to most AC hardware.
Leslie this is about plumbers tape, as you live below see level, maybe you should try this before the next flooding.
Step1
- Joined on 07-06-2008
- Manchester
- Posts 961
Søren Mexico:
Step1:
Certainly wouldn't want to bung those holes up with your finger (Hans Brinker style) lol!
Rich
- Joined on 07-11-2010
- Orlando, Florida, USA
- Posts 1,089
Specialty power, interconnect, and speaker cable talk always makes me think back to the good old days when people believed green marker around the perimeter of CDs made them sound better.
I hear voodoo dolls work, also.
It's this simple: if you believe something will sound better after some tweak or another, it will.
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
Rich:
You just caught the over-hyped fashions of audiophile business. The placebo effect is working if you really believe that the change makes the big difference.
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
Ulf
- Joined on 04-17-2007
- Germany
- Posts 665
www.audio-tuning-tools.de
Only German but very nice ;)
Voodoo ???
Page 1 of 1 (19 items)
