They should work fine with an Ouverture.
On the side of the amps, at the display end, you will find a 3 position switch. Make sure that it is in AUDIO mode.
On the back of the amps, make sure that either L or R is selected on the mode switch.
You will need Mk2, sometimes called fully wired powerlink cables or the displays will not work.
