Latest post 07-07-2011 5:51 AM by JC. 1 replies.
Page 1 of 1 (2 items)
  • 07-06-2011 11:07 AM
    • Tomvdw
    • Top 500 Contributor
    • Joined on 04-21-2007
    • Germany
    • Posts 109
    Ouverture - glass doors sliding problem
    my new bought 2nd hand Ouverture have problems with its sliding mechanism - sometimes the doors closes not completely, the gap between differs between 2 - 60 milimeter when 2 mm are fine and normal. I cleaned up the running rails already but I assume, it might be a problem with the rubber band - as the prev. owner were heavy smokers :( and I already spent hours to clean this piece of 90´s - original, it has some further issuers I resolved already (described in the german board).
    Does anybody have a guidance for me, how to replace the rubber band ?
    The teardown of the mechanic is the one I need help for, the rest is easy for me now ;-)
    Thanks in advance/Regards
    Tom
    Filed under:
  • 07-07-2011 5:51 AM In reply to
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    Re: Ouverture - glass doors sliding problem
    Hi Tom, more likely that the cable has stretched over time. Common on older overtures and can be tightened. Think it tells you how to in the service manual.
      Jonnie
