Latest post 07-04-2011 4:08 AM by Agent00soul. 13 replies.
Page 1 of 1 (14 items)
  • 07-03-2011 2:12 PM
    Beocord 2000K reel to reel
    Hi All,
    I've picked one of these up very cheaply - it seems to work fine playing pre-recorded tapes but I really don't have a clue what most of the slider controls and inputs do. Any advice would be greatly appreciated or does anyone know where I can get a user manual for this?
    Thanks,
    Paul
    Warrington, UK
  • 07-03-2011 2:34 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocord 2000K reel to reel
    Welcome to Beoworld !
    They are wonderful machines !
    Here is a scan of the original sheet that came with the Beocord :
    and here:
  • 07-03-2011 2:41 PM In reply to
    Thanks Martin - that's brilliant.
    Mine isn't a Deluxe model but there doesn't look a lot of difference -split faders on the diagram I think. It sounds fantastic on the tape that came with it plus it was supplied with 15 blank new/sealed tapes of similar vintage
    Paul
  • 07-03-2011 3:10 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-10-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    its4paul:
    Mine isn't a Deluxe model but there doesn't look a lot of difference -split faders on the diagram I think. It sounds fantastic on the tapes that came with it - I paid £40 for it including 16 blank new/sealed tapes of similar vintage
    Paul
    Geeked
    Never in the States....
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 07-03-2011 4:32 PM In reply to
    One other question - probably down to me not understanding what the 2000K can do - I have tried to play a couple of tapes recorded on my Sony TC630 and they play backwards and sound distant as if I've got the tape on wrong. I'm guessing its the head alignment but I dont know - the Sony recorded 2 track stereo so they should play.
    Sorry if I sound like a total novice here... Confused
  • 07-03-2011 4:47 PM In reply to
    • Dillen
    • Posts 5,008
    Callout 2 on the first diagram is a button to select between 2 and 4 tracks.
    I suggest you try this with your Sony tapes.
  • 07-03-2011 4:52 PM In reply to
    Ah... thought that might be the answer - but my 2000K doesn't have that button.... Huh?
  • 07-03-2011 5:02 PM In reply to
    • Dillen
    • Posts 5,008
    OK, then try winding the tape to the other end and start playing from there.
  • 07-03-2011 5:05 PM In reply to
    The button was only on the Deluxe version. Try what Martin suggested. You can actually play two track tapes on a four track recorder (they thought of that when developing four track). The other way around is not possible.
  • 07-03-2011 5:10 PM In reply to
    Tried that too. Have also tried tapes recorded on a mono Grundig and a mono Philips, all of similar vintage and all do the same. However, one thing I'm wondering... I am playing the output via the line out to an amplifier at the moment, not to speakers so I was wondering if the line out routing is different.
    Thanks for the suggestions - very much appreciated.
    Paul
  • 07-03-2011 5:18 PM In reply to
    I thought the 2000K was a 4 track (at least 2 tracks either direction) so it should play the Sony tapes recorded in stereo on 2 tracks. I understand this model was a development of the Stereomaster 610K http://beocentral.com/beocordstereomaster610k  - looks just what I've got in front of me Smile
    Thanks again
  • 07-03-2011 5:21 PM In reply to
    Ah just read the spec properly - maybe I do have the 2 track version after all... not sure how I can tell though Erm
  • 07-04-2011 2:50 AM In reply to
    • Dillen
    • Posts 5,008
    You can look at the tapeheads. If there is a gap between the two track elements of apprx the
    same size as the elements themselves, you have a 4-track.
    If the elements are close together, covering almost the entire tape width, it's a 2-track.
    A tape recorded on a mono machine will typically have one track playing fine with the other track
    playing something else in reverse.
    On a stereo machine, you must then play only one channel at a time, typically the left one.
    Having said that, there were uncommon recording formats around that will only play correct on the same type of
    machine that recorded the tape.
  • 07-04-2011 4:08 AM In reply to
    Thanks for this scan Martin. I have a DeLuxe which I found in the electronics thrash dumpster where I live. After replacing the pinch roller, it plays fine but I couldn't check all functions as I didn't know what all buttons did.
