Latest post 08-11-2011 2:52 AM by SteveB. 10 replies.
Page 1 of 1 (11 items)
  • 06-28-2011 6:07 AM
    Missing N Radio Stations
    Just noticed that some of my N Radio stations have disappeared from my Beosound 5. Including Radio 1 here in the UK. Has anyone had the same issue?
  • 06-28-2011 8:19 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Missing N Radio Stations
    andyt1979:
    Yes, if a station is to often "not available" (tech problems or simply to many listeners)
    it is taken (temporarily) of the "list".
    Happened to me several times - beeing a listener of ABC-Classical - it was gone, reappeared on the "list" , disappeared ...
  • 06-28-2011 8:30 AM In reply to
    I wonder if it was because it was the Glastonbury festival here in the UK over the weekend. Radio 1 was covering this live. This may explain it!!
  • 06-29-2011 4:40 PM In reply to
    Nope still no Radio 1. Has this happened to anyone else???
  • 07-02-2011 6:45 AM In reply to
    • Electrified
    • Top 150 Contributor
    • Joined on 10-05-2009
    • Greater Copenhagen, Denmark
    • Posts 404
    andyt1979:
    Could this be it:
    http://forum.beoworld.org/forums/p/39086/324877.aspx#324877
  • 07-02-2011 11:00 AM In reply to
    • Vienna
    • Posts 712
    As far as I know, the list of selected stations is updated regularely, but not on a daily or even weekly schedule.
    Last time it took approx a month till my favorite ABC-Classical was back on the list - you'll have to be patient ...
  • 08-10-2011 1:14 PM In reply to
    Steve
    andyt1979:
    Dear andyt1979,
    I just wondered if you managed to resolve this, I listen to Radio 1 frequently and last weekend it just disapeared from the list. Have tried powering down and removing the mains plug for a while and also a recovery from the service menu with no luck and my dealer does not know how to resolve this
    Many thanks
  • 08-10-2011 3:26 PM In reply to
    Hi there. Yes it's back. Apparently B&O have a central server for N Radio stations which has a master list. Sometimes B&O drop stations if there stream drops below a certain standard.
  • 08-10-2011 4:54 PM In reply to
    • Vienna
    • Posts 712
    andyt1979:
    That's the way it works.
  • 08-11-2011 1:57 AM In reply to
    Yes, they monitor all stations over a period, and if the down time is too high, the station is removed. When the station is stable again, it goes back to the list automatic.
    I just had the case with 2 stations, one of them is back again, I wrote a mail to the other station that their net station is very unstable.
    There is something about B&O.....
  • 08-11-2011 2:52 AM In reply to
    Thanks Guys
    Really appreciate the responses, its weird it seems that its only my BS5 thats missing BBC Radio 1 so it cannot be that B&O have removed this from their central server list
    Any other suggestions to get it back?
    Steve
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
