Hi, I have what should be a pretty simple system but I want to make some changes.
Setup:
Beosound 5 (Audio Master, option 0) and Beolab 6000 speakers in living room
Samsung TV connected to the Beosound and playing through the “PC” function on the Beo 4 remote
Beolab 3500 in the bedroom
I am not satisfied with the TV sound quality coming through the system (strange, but it’s actually hard to understand what is being said on TV sometimes).
As a result of this setup I cannot control the Beosound volume on the display.
Now I would like to disconnect the TV, regain full functionality on the Beosound 5 (volume control) and not change the way the Beolab 3500 works.
What option settings should I use in the Audio Master setup on Beosound 5? I can’t find instructions on how to do this anywhere. What do the different options do? How do they affect my system?
Thank you!
Alex
