Latest post 02-27-2012 8:55 AM by Dean. 6 replies.
Page 1 of 1 (7 items)
  • 06-18-2011 6:32 PM
    Sky HD 1TB box problem with IR controller
    I have just taken delivery of a new Sky HD 1TB box. I connected it up to my Beovision 7-40 tv. Initially I couldn't work the box via my BeO4 remote. I managed to get it to work by moving my sensor atround the front of the box. After switching the tv off the following day I was unable to get it to work again. Has anyone else had this problem and if so has anyone got a solution.
    cheers Paul
    Filed under:
  • 06-18-2011 6:38 PM In reply to
    Re: Sky HD 1TB box problem with IR controller
    yeah the ir sensor is in the middle of the digibox (the display part with play logo) I had to stand mine off using a loop of tape to work correctly i will post a picture in the morning if you need one?
    Cheers Nick
  • 06-19-2011 3:13 PM In reply to
    Thx mate I will try that. A pic would be even better. Cheers
    Paul
  • 06-19-2011 3:47 PM In reply to
    message me with your email and I will send it over, cheers Nick
  • 02-25-2012 6:59 AM In reply to
    • Dean
    • Not Ranked
    • Joined on 09-03-2009
    • Posts 13
    hi i also have just got the new sky 1tb box and stuck mine to the left of the logo whihc seems to works.
    Please advise what software you are using from your list in the stb, I have used the thomson one which all works apart from when entering your pin code iinto the control for the movies the tv turns of whci i dont now whats wrong
  • 02-25-2012 4:03 PM In reply to
    I have had this issue - pressing the zero digit button switches the box on and off!
    You could try a different PUC such as Pace Sky+
    Or if it is a PIN code issue, try changing your PIN so it doesn't include a zero?
    Dean:
    I would anticipate a software fix shortly!
    BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
  • 02-27-2012 8:55 AM In reply to
    • Dean
    • Not Ranked
    • Posts 13
    thank you i manged to fix the problem, i selected a different box in the stb menu and all working perfectly fine, i spoke to a b&o enginner who advise that he always has problems with amstrad boxes and to use either a thomson or pace stb software.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
