I have had this issue - pressing the zero digit button switches the box on and off!
You could try a different PUC such as Pace Sky+
Or if it is a PIN code issue, try changing your PIN so it doesn't include a zero?
Dean: when entering your pin code iinto the control for the movies the tv turns of
I would anticipate a software fix shortly!
BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
