Latest post 06-14-2011 1:21 PM by classic. 6 replies.
Page 1 of 1 (7 items)
  • 06-14-2011 11:14 AM
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Unseen B&O Headphones..
    Thanks to Martin (Dillen) I picked these headphones up on a Danish website.
    They sound absolutely superb - on a par with my Grado's in fact!  However, I know absolutely nothing about them.
    I'll start with the casing of the 'cans' on which is written 'VibroCard' - Bang & Olufsen Technology.
    The coating on the earpads is very similar to the covering on the U70's, and indeed it's beginning to peel off like they do since i've started using them regularly.  The cable which goes from the headphones and terminates in a 3.5mm jack also has 'Audio Technica - ARTLINK - Titan' printed on it.
    So.. help me out.. what's the history of these great sounding headphones?!  I'm intrigued.. Hmm
    Lee
    Smile
  • 06-14-2011 11:36 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Re: Unseen B&O Headphones..
  • 06-14-2011 11:37 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    and finally..
  • 06-14-2011 12:21 PM In reply to
    • Puncher
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
     - possibly from the Medical Division???
    The only references I can find seem to be regarding audio diagnosis of cardiolgical problems using some sort of audio analyser...maybe the headphones were supplied with that?Hmm
  • 06-14-2011 12:44 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Medicom was my initial thought due to the colour.  Functional as opposed to pretty, so suited to more of a working environment..
    They are very well insulated from outside noise - and the clarity of them is amazing, really.
    I'm sure someone will have seen these before... Surely!
    Lee
  • 06-14-2011 1:03 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-11-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    While I can offer nothing by way of their history, may I suggest there is one word to describe them:  groovy!
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 06-14-2011 1:21 PM In reply to
    • classic
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Venø - Struer / Denmark
    • Posts 224
    ............Bang & Olufsen Technology udvikler endvidere medicinsk måleudstyr (Vibrocard).
    ... recordings were reproduced on a laptop computer (IBM T41) through an external soundcard (24bit Sound Blaster Audigy2 NX) and headphones (B&O VibroCard). ...
    Google search results
    Yes you were right - Medical Bang & Olufsen products
    /Frede
    Beolab 5000 -  "If another amplifier sounds different then it needs repair!"
