Thanks to Martin (Dillen) I picked these headphones up on a Danish website.
They sound absolutely superb - on a par with my Grado's in fact!  However, I know absolutely nothing about them.
I'll start with the casing of the 'cans' on which is written 'VibroCard' - Bang & Olufsen Technology.
The coating on the earpads is very similar to the covering on the U70's, and indeed it's beginning to peel off like they do since i've started using them regularly.  The cable which goes from the headphones and terminates in a 3.5mm jack also has 'Audio Technica - ARTLINK - Titan' printed on it.
So.. help me out.. what's the history of these great sounding headphones?!  I'm intrigued..
Lee
