        1st March February 2012
	    Latest post 06-10-2011 8:40 AM by  frog. 29 replies.
								        06-06-2011 3:51 AM
									        wood
								                - Joined on 04-20-2007
								                - Posts 42
										    BeoSystem 3 and Apple TV 2
										    I have a BeoSystem 3 (SW-Version 10.02a) and i have connect a Apple TV2 via HDMI. The problem is: unfortunatly no picture (black screen), but the sound is working.
Can anybody help?
Thanks and best regards
Fredy
									        frog
								                - Joined on 04-19-2007
								                - Posts 191
										    Re: BeoSystem 3 and Apple TV 2
										    I get this occasionally - use the apple remote to ensure the appleTV is sending something after powering the Beosystem 3 down for 30 seconds - then on again. I think there is some issue in recognising the HDMI signal.
									        wood
								                - Posts 42
										    thanks, frog, but unfortunatly this has not helped. still black screnn. audio is working. are there anything else what i can do?
Fredy
									        DoubleU
								                - Joined on 05-09-2007
								                - Posts 866
										    Another cable, different input, hook up your ATV to another tv. Isolate the problem first and go from there.
									        wood
								                - Posts 42
										    yes, i have tried:
- other cables= doesn't work - different inputs on BS3 = doesn't work - ATV works fine when i connect direct to a TV
  thanks for more help
Fredy
									        Ehlerz
								                - Joined on 04-17-2007
								                - DK
								                - Posts 510
										    Hi Fredy
What source have you chosen to connect the Apple Tv to?
For instance, choosing V.mem, you will have to configure the settings in the BS3 menu to have HDMI A, B, C or D(depending on which one you have chosen) associated  to V.mem.
This may be obvious and you might already know, but just to be sure :-)
Which screen do you have?
/Ehlerz
									    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
									        wood
								                - Posts 42
										    hi Ehlerz, i use "DTV2" and i have cosen the associat HDMI-Port on the BS3. I use a Pioneer Kuro screen on the BS3. If i connect the ATV diect to the screen, everthing is fine.
Fredy
									        egoh
								                - Joined on 04-12-2011
								                - Austin, Texas - USA
								                - Posts 77
										    Have you tried messing with the output resolution setting on the ATV? I've had issues with my ATV1 and some older TVs.
									        BeoMegaMan
								                - Joined on 11-25-2007
								                - Posts 66
										    This may sound crazy but my guess is you are using hdmi 1.3v or lower cables. If you have a the most recent ATV2 update it seems to induce a handshake error on certain screens. A couple clients have had all working but then would not be able to watch say Netflix or a purchased itunes movie... the whole time being able to see the itunes menu and operate it as normal. It may pain you but you may have to pay for a new 1.4v cable and make sure it is firmly seated (seems the ATV2 also has a sensitive connector. I have had to due this on all B&O TV's that share some of the same problems you are having. This isn't a B&O only issue but seems to be a known issue in the ATV2. Simply do a search on google for ATV2 HDMI and you can see what some other people have done (including the above) to resolve the issues with their non B&O screens (powering down the tv, plugging and unplugging etc.) And as always make sure you are running the newest BS3 software as well. Just throwing out what I've run into.
									    BV7-40 MKIV, BeoVision Avant 32, BeoVision 8-32, BeoLab Penta MKIII, BeoLab 6000 x 3, BeoSound 9000 MKIII, BeoLab 7-4, BeoSound 4000, BeoPort, BeoVox S45-2, ML/MCL Convertors, A8's & Form 2's.
									        wood
								                - Posts 42
										    Ok, i will buy a new HDMI cable and try again. Thanks for all your help.
									        wood
								                - Posts 42
										    or has this to do with HDCP? Is my BeoSystem compatible with HDCP?
									        symmes
								                - Joined on 04-21-2007
								                - Freedonia
								                - Posts 290
										    BeoMegaMan's response reminded me that we had 2 TV's respond badly to the last ATV2 update.  One just had to be powered down, but the other had to do a full reset (including account info) to get working.
									        wood
								                - Posts 42
										    Now i have change the cable, reset fully the screen, but still black. Nothing helps. Any more ideas?
Thanks and regards
Fredy
									        DoubleU
								                - Posts 866
										    Did you try another source?
									        wood
								                - Posts 42
										    yes, i have tried different sources, but no success.
									        wood
								                - Posts 42
										    Are there any other ideas how i can run an ATV2 on my BeoSystem3?
Fredy
									        DoubleU
								                - Posts 866
										    You tried another source, so the ATV2 has nothing to do it. Tried another cable. Different inputs on your BS3. Still no go.
So get your BS3 updated/repaired! I see no other option.
									        Karla
								                - Joined on 08-19-2008
								                - USA
								                - Posts 81
										    I learned much more than I ever wanted to know about HDMI when I decided to hook up the ATV2 to my Avant.
The problem that you are encountering is a security issue between the ATV2 and the B3. The ATV2 is looking for a security signal from the B3 which is designed to guard copyright protection, and while the lack of the security signal will usually generate audio, the video will then be altered in two common variants: black and white picture or no picture at all. You have proven that the ATV2 is in fact capable of generating the video by connecting it directly to your television.
This leaves you with the following options:
1.    Contact B&O and find out if there is an update for the B3 to support the security signal.
2.    Bypass the B3 and connect directly to the television.
3.    Completely counterintuitive, but: hook up a convertor between the ATV2 and the B3, and feed the B3 through the non-HDMI connection. Below is my post as to what I used to convert the HDMI for use on the Avant:
The Apple TV 2nd Generation (black) works with the Avant! The solution: feed the HDMI through the LinkStyle HD Video Convertor LK-219414. It gives wonderful color and the sound is perfectly synched. I purchased it from Amazon for $53.99 plus shipping. Have fun and enjoy!
									        wood
								                - Posts 42
										    Thank you very much for your answer. I try to find such a converter here in Switzerland do it in the same way as you did. As soon as i have installed such a converter i will report the results.
cheers
Fredy
									        symmes
								                - Freedonia
								                - Posts 290
										    This is good stuff Karla.  Did you use an a/b switchbox for the "extra" component cable set? Thanks.
I have not run across a handshake issue with BeoSystem 3, and we have an early series 1 in the store.  If there were a handshake issue, it must have been resolved with software update.  It appears the last time an update addressed HDMI issues was October 2009.
What I haven't done is run to a non-B&O screen.  Is it possible the handshake issue is between BeoSystem 3 and the Pioneer?  We have run Apple TV2 to every recent B&O television with nice results.
BTW, going to try Roku box next, because it has Hulu+ and many options for on-demand TV.  There goes another HDMI port.
									        frog
								                - Posts 191
										    HDCP is in passthrough mode in the Beosystem 3 - so that isn't the problem - and i'd hesitate on buying a new box - specially as it downscales unnecessarily for your needs. The issue with the avant is different as it is the downscaler box that needs to have an active HDCP key as it is a terminator (and not really legal :) ).
One thing I'd suggest is to go into the customer menu (MENU, MENU, move to OPTION, then press RED then GO) and check that the monitor output is set to 60hz - it may be that your screen is rebelling against the input from the Beosystem 3.
									        wood
								                - Posts 42
										      frog:
hi frog, that i have already done, the monitor output is at 60Hz. On the other hand, i have already 2 other inputs (a bluery player and a settop box), both are using a hdmi-input on the BS3 and they are working fine. So, this must be something between the ATV2 and ther BS3.
									        DoubleU
								                - Posts 866
										      wood:
Yesterday you said you tried different sources, with no succes..
									        wood
								                - Posts 42
										    sorry, must be a misunderstanding: yes, i have tried different sources/connectors at the BS3 with ATV2 (on the hdmi-input A i have a settop-box, on the hdmi-input B i habe a bd-player, at the hdmi-input C i have connected the ATV2. The settop-box and the BD-player are working fine, ATV2 ist "dark" (audio ist working, but no video).
sorry again for this unclear explanation from my side.
Fredy
									        BeoMegaMan
								                - Posts 66
										    Maybe a swap of the ATV2? I have seen in the Apple forums that some customers have been able to swap theirs out and it cleared up the issue. Additionally, you may try to set your BS3 into Framelock - Double Buffer as another work around......(red + go while on options then select picture adjustments).... I seem to remember that working on the old ATV1 with the old BV7's, but that was a B&O screen.......
