A Very Warm Welcome to Beoworld..
I do not have an XML file for this model Samsung LED TV, but one could be made if you could find the IR codes.
There are really three main ways of getting these IR codes:-
- Capture them from the original remote (Best way)
- Find Pronto HEX codes on the web at sites like www.remotecentral.com
- Some manufacturers publish the codes on their web site
So, the first task is to find the IR codes associated with this Samsung model.
