Latest post 10-09-2011 11:11 AM by Coolblue86. 11 replies.
Page 1 of 1 (12 items)
  • 06-05-2011 5:44 AM
    XML File for Samsung UE46B8090
    I am locking for a XML for this LED-TV. I have a Beo5 Remote.
    Best regards, Bianca
  • 06-05-2011 12:15 PM In reply to
    Re: XML File for Samsung UE46B8090
    A Very Warm Welcome to Beoworld..
    I do not have an XML file for this model Samsung LED TV, but one could be made if you could find the IR codes.
    There are really three main ways of getting these IR codes:-
    1. Capture them from the original remote (Best way)
    2. Find Pronto HEX codes on the web at sites like www.remotecentral.com
    3. Some manufacturers publish the codes on their web site
    So, the first task is to find the IR codes associated with this Samsung model.
    Regards Keith....
  • 06-06-2011 3:06 AM In reply to
    I have found a link for thie ir-codes:
    http://www.remotecentral.com/cgi-bin/mboard/rc-discrete/thread.cgi?2792
    Important is: Power, Source(Input), Volume and player-functions(FFW, Stop, etc...)
    Bianca
  • 06-06-2011 1:19 PM In reply to
    Bianca,
    The link does not appear to cover all the common commands, but I have created an XML file with some of them which you can download HERE. The digit hard keys are assigned and STEPUP and STEP down on the hard keys are channel up/down. Also the volume dial codes are assigned.
    Please test the file remembering that only a few of the commands have been added
    Regards Keith....
  • 06-06-2011 4:04 PM In reply to
    Hi!
    It doesnt work :-(
  • 06-06-2011 4:15 PM In reply to
    lazarus1:
    It doesnt work
    Well Clearly the Pronto IR codes you found were not compatible with your Samsung unit.
    You best approach is to capture the IR codes from the Original remote control, then you will know for certain that it will work.
    Regards Keith....
  • 06-09-2011 9:50 AM In reply to
    Dear Lazarus1,
    There is an XML-file for a Samsung LCD in my account, try this one. It works fine with my new Samsung LCD (direct with BEO5 and -6).
    Dave
  • 06-09-2011 10:56 AM In reply to
    Hey!
    Thanks. It works fine :-)
    Is it possible to use the hard-buttoms with the colors and the cursor?
    Thanks!
  • 06-09-2011 11:06 AM In reply to
    lazarus1:
    This XML file is one I have previously produced which has the hardkeys assigned including the colour buttons.
    Open the file with a text editor such as Windows Notepad and you can see for yourself.
    Regards Keith....
  • 06-09-2011 2:30 PM In reply to
    The hardkeys doesnt work!
  • 10-03-2011 6:53 AM In reply to
    i use the same file.
    it works for my samsung UE40D6510.
    i get the hardkeys to work, but not the volume buttons.
    any help?
  • 10-09-2011 11:11 AM In reply to
    in the xml file there are several buttons missing:
    Smart-Hub
    Guide
    Info
    Tools
    3D
    Channel-List
    Is it possibel to get this buttons, too?
