The directory which holds XML files for DIRECT control is:-
C:\Bang & Olufsen\Beo5 Configuration Tool\ThirdParties
As previously explained, if a member of Beoworld has not made an XML file for these STB's, then you would have to make one yourself or get someone to make it for you, but before you can make it, you need to find the IR command codes for these STB's.
There are really three main ways of getting these IR codes:-
- Capture them from the original remote (Best way)
- Find Pronto HEX codes on the web at sites like www.remotecentral.com
- Some manufacturers publish the codes on their web site
So, the first task is to find the IR codes for your two STB boxes.
