Latest post 06-04-2011 10:27 AM by Evan. 3 replies.
Page 1 of 1 (4 items)
  • 06-04-2011 3:11 AM
    • Alias
    • Top 500 Contributor
    • Joined on 04-23-2008
    • Posts 90
    IR Receiver?
    Hi
    I connected my BV4-50 with a Onkyo NR-TX1008. The Onkyo is hidden in a cabinet. Unfortunately I canot control the Onkyo through the cabinet with my Beo6 IR, so I have now a Logitech Harmony 900. To be honest the Beo6 looks much better and I would like to use it. So my question: is there something like a IR receiver? I would like to set up the IR receiver next to the cabinet and put the other end into the cabinet. So that I can control my Onkyo without opening the cabinet.
    Thank you in advance
  • 06-04-2011 7:31 AM In reply to
    Re: IR Receiver?
    If your third party STB is hidden in a cabinet, then your best option would be a Lintronics box.
    Regards Keith....
  • 06-04-2011 9:43 AM In reply to
    Re: IR Receiver?
    I have used these in the past. Just sold a pair on ebay last month.
    Powermid
    Or maybe the newer version
    PowermidXS
    There are better, more complicated/expensive/B&O compatible versions out there. The issue is these are not "B&O compatible" but as you are using a Beo6 you would most likely be using Onkyo codes via Beo6 and not B&O codes so I'd think it would work.
    Stoobie
  • 06-04-2011 10:27 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: IR Receiver?
    Since you are operating within a cabinet, you probably also have room to use a wired IR repeater.
    Niles has a ton of IR integration products.
    http://www.nilesaudio.com/product_selection.php?catcdID=5
    Evan
