Latest post 06-06-2011 1:47 PM by Blackrix. 5 replies.
Page 1 of 1 (6 items)
  • 06-03-2011 8:31 AM
    beolink 5000
    Is Beolink 5000 ok for a beomaster 7000? or is it necessary other beolink? Thanks
    Filed under:
  • 06-04-2011 8:43 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: beolink 5000
    The BL5000 will be fine with a BM7000 & offer 2 way communication - right up until the point where you accidentally drop it & it stops working, they aren't particularly robust I'm afraid.
    Other options are :- Beolink 1000, MCP6500/5500, Beo4/5/6 & of course the Beolink 7000.
    Chris.
  • 06-05-2011 7:35 AM In reply to
    Re: beolink 5000
    I have one comment regarding the other options. With Beo4 it is not possible to tune the BeoMaster 7000, since the function TUNE or GOTO is not in the LIST functions under Audio!
  • 06-05-2011 8:13 AM In reply to
    Re: beolink 5000
    Blackrix:
    Actually it is possible, but it requires a trick with option 2 (so the Beomaster follows the video mode TUNE command) and is quite annoying:
    http://forum.beoworld.org/forums/t/26744.aspx
    Anyway, everybody should have at least one Beolink 1000! Smile
    -mika
  • 06-05-2011 10:44 AM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: beolink 5000
    And if you have all your favorite stations stored as presets it's no problem to tune it with a Beo4.
  • 06-06-2011 1:47 PM In reply to
    Re: beolink 5000
    That's not tuning, that's changing presets!Wink I mean if you want to search for a station and store it on a preset.
    I knew the Option 2 solution, but that's not a very user friendly solution. I'd go for a BeoLink 1000!
