Latest post 06-03-2011 1:39 PM by Evan. 4 replies.
Page 1 of 1 (5 items)
  • 06-02-2011 9:31 AM
    beolab 3500 as a center speaker
    Hi
    I'm running my rec room audio (satelite tv, Cary CD player, DVD player) through an old AV7000. What pieces do I need to use a beolab 3500 as a center speaker controlled by my AV 7000? A beolink converter?
  • 06-02-2011 9:39 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: beolab 3500 as a center speaker
    From what I remember, there is an independant company that,makes this possible. A bit of searching should uncover the company, I'll go have a look.
    Evan
  • 06-02-2011 8:28 PM In reply to
    A topic that has been discussed here many times. Here is the link to the product that Evan is thinking about. They have been around for a while, but I can't remember any posting from a member who has tried this.
    I can tell you that IMHO the BL3500 is completely inadequate as a center speaker, even with an AV7000. Again, it's just my opinion as a current BL3500 this is not the right speaker for the job. I love it as a link speaker, I think that the design is teriffic, and from a sound point of view adequate as a link.
    I also owned an AV7000 (once upon a time) and I would think that it's propbably not worth investing a lot in keeping it alive. Might I suggest a descent pair of passive speakers for your center channel project?
    BTW, Cary CD player... Wow.
  • 06-03-2011 9:45 AM In reply to
    Hi
    Thanks for the info.  I'm sticking to 2 channel but will need something to use as a center instead of 1)my crappy tv speakers or 2)not using my 2 channel beolab 1 for the tv .  An inexpensive pair of passive speakers is probably a good suggestion. I liked the look and packaging of the beolab 3500 (slim and can be wall mounted) and since it won't function as a true "center" in a surround sound, it only needs to be better than my tv speakers.
    Thanks for your help
    Henry
  • 06-03-2011 1:39 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    For high performance surround listening, the 3500 is not ideal. But from what you illstrate, Henry, it sounds like a fine way to do things.
    Evan
