        1st March February 2012
	    Latest post 06-12-2011 8:00 AM by  Beobuddy. 11 replies.
								        06-02-2011 4:02 AM
									        Noah
								                - Joined on 12-16-2008
								                - Switzerland
								                - Posts 120
										    Beolink 5000 doesn't work anymore
										    Hello
Today I wanted to use my Beolink 5000. As I put the batteries in the display only shows STD.BY and the rc won't react when i push any button. It won't send any commands to my Beosystem 7000 too!
What went wrong? Last time I used it the rc worked very well.
I am glad for your help.
Noah
									        kallasr
								                - Joined on 04-19-2007
								                - Willich, NRW, Germany
								                - Posts 1,077
										    Re: Beolink 5000 doesn't work anymore
										    Try using a mobile phone lens/digital camera and look through it pushing the buttons of the remote. You will see it blink - if it works.
Then maybe playing with options, changing the mode of the Beolink etc. might help. Search the forum!
Ralf
									    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
									        lausvi
								                - Joined on 04-16-2007
								                - Helsinki - Finland
								                - Posts 498
										    Is the display on all the time (and showing STD.BY)? It should go blank after few moments when idle. Could the stand-by button be stuck?
									    Bang & Olufsen - The art of controlling sound, picture and light
									        Noah
								                - Switzerland
								                - Posts 120
										    Yes. The display show all the time STD. BY.
I will check the stand-by button.
									        Beobuddy
								                - Joined on 04-18-2007
								                - Posts 1,582
										      Emil:
A longshot but maybe worth a try - have you checked whether your rc is set to two-way or one-way communication? During the last years of it's active life (screen only shows a few pixels nowadays) my Beolink 5000 could change from two-way to one-way without no particular reason. If you have had no batteries in for a while that could maybe trigger such a reaction.
It is otherway around.
Standard the BL5000 is 2-way, which can be set manually to one way. If a powerfaillure occurs, then the BL5000 falls automatically back to 2 way.
The BM7000/system 7000 handles 2 and 1 way without any problem.
Could indeed be one of the buttons which is stuck. Try the camera trick (optional: while inserting the batteries)
									        Hungedu
								                - Joined on 08-08-2009
								                - Ambergris Caye, Belize
								                - Posts 128
										    Unfortunately, the BL-5000 is a very fragile remote. Mine started having problems without any cause, so I got rid of it. I noticed a lot of others selling defective BeoLink 5000 remotes on eBay. Usually, the LCD pixels start going bad first, but I have not heard of the keypads being non-responsive. I miss the 2-way communication, but love the more hardy construction of the Beo 4.
BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.
									        Emil
								                - Joined on 05-18-2007
								                - Stockholm, Sweden
								                - Posts 98
										      Beobuddy:
  Emil:
 My bad. Used to have a MX 7000 (one-way) and a BeoSystem 2500 (two-way) where I constantly had to change the one-wa/two-way option. Makes however sense when you say it since the BS2500 could handle booth communication types while the MX 7000 only could take one-way.
 In any case - an interesting problem. Would be interesting to know about if ever solved, which I hope. It's indeed a very nice remote. Miss the two-way communication so I'll probably get me a Beo6 once they have rolled out the software update for BeoSound 5.
									        stefan
								                - 200 miles from Struer
								                - Posts 1,733
										    I think lausvi is right. Must be the STDBY button. Hide your BL5000, activate your BS7000 manually and get your BL5000. It should set the BS7000 to standby without pressing a button, because it sends a STDBY command all the time, which results in a STDBY SYSTEM command. I had a similiar problem with a BL1000 years ago. It was the VOLUME UP button, which can get dangerous - for the speakers....
Stefan
									        Noah
								                - Switzerland
								                - Posts 120
										    Hello guys
Nope. The 5000 sets the Beosystem 7000 not to stand-by when I put the batterie in! I don't thinit is the stuck stand-by button![:'(] But when I put the battteries in the Beolink sends a command but the Beomaster does not react.
So I have no idea what is wrong with that remote.  Makes my angry!!;-)
Noah
									        Beobuddy
								                - Posts 1,582
										    Start from the beginning. Set your BM7000 in option 1 (if that's the only set you have without connected to a Beovision etc)
So, take another remote (Beo4 eg), and set the BM7000 to A-OPT 1.
  Noah:
Ok, checked with a camera? Could be an instruction from the Beolink 5000 asking for status information from the BM7000.
        Page 1 of 1 (12 items)
