Latest post 06-12-2011 8:00 AM by Beobuddy. 11 replies.
Page 1 of 1 (12 items)
  • 06-02-2011 4:02 AM
    • Noah
    • Top 500 Contributor
    • Joined on 12-16-2008
    • Switzerland
    • Posts 120
    • Silver Member
    Beolink 5000 doesn't work anymore
    Hello
    Today I wanted to use my Beolink 5000. As I put the batteries in the display only shows STD.BY and the rc won't react when i push any button. It won't send any commands to my Beosystem 7000 too!
    What went wrong? Last time I used it the rc worked very well.
    I am glad for your help.
    Noah
    Filed under:
  • 06-05-2011 3:26 PM In reply to
    • Emil
    • Joined on 05-18-2007
    • Stockholm, Sweden
    • Posts 98
    Re: Beolink 5000 doesn't work anymore
    A longshot but maybe worth a try - have you checked whether your rc is set to two-way or one-way communication? During the last years of it's active life (screen only shows a few pixels nowadays) my Beolink 5000 could change from two-way to one-way without no particular reason. If you have had no batteries in for a while that could maybe trigger such a reaction.
    Inflagrante
  • 06-06-2011 2:26 AM In reply to
    • Noah
    • Switzerland
    • Posts 120
    • Silver Member
    Thank you for the hint. But sadly my Beolink 5000 does not react to any button of the keypad. The display shows all pixels (luckely ;-)) and  says only STD. BY. Nothing else! If I push CD, Radio, TV, etc non of my B&O equipment reacts, so the Beolink does not send a code. I think.
  • 06-06-2011 2:38 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Try using a mobile phone lens/digital camera and look through it pushing the buttons of the remote. You will see it blink - if it works.
    Then maybe playing with options, changing the mode of the Beolink etc. might help. Search the forum!
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 06-06-2011 5:06 AM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Is the display on all the time (and showing STD.BY)? It should go blank after few moments when idle. Could the stand-by button be stuck?
    Bang & Olufsen - The art of controlling sound, picture and light
  • 06-09-2011 6:29 AM In reply to
    • Noah
    • Switzerland
    • Posts 120
    • Silver Member
    Yes. The display show all the time STD. BY.
    I will check the stand-by button.
  • 06-09-2011 11:14 AM In reply to
    Emil:
    It is otherway around.
    Standard the BL5000 is 2-way, which can be set manually to one way. If a powerfaillure occurs, then the BL5000 falls automatically back to 2 way.
    The BM7000/system 7000 handles 2 and 1 way without any problem.
    Could indeed be one of the buttons which is stuck. Try the camera trick (optional: while inserting the batteries)
  • 06-09-2011 1:23 PM In reply to
    • Hungedu
    • Joined on 08-08-2009
    • Ambergris Caye, Belize
    • Posts 128
    Unfortunately, the BL-5000 is a very fragile remote. Mine started having problems without any cause, so I got rid of it. I noticed a lot of others selling defective BeoLink 5000 remotes on eBay. Usually, the LCD pixels start going bad first, but I have not heard of the keypads being non-responsive. I miss the 2-way communication, but love the more hardy construction of the Beo 4.
    BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.
  • 06-09-2011 5:31 PM In reply to
    • Emil
    • Stockholm, Sweden
    • Posts 98
    Beobuddy:
    Emil:
    My bad. Used to have a MX 7000 (one-way) and a BeoSystem 2500 (two-way) where I constantly had to change the one-wa/two-way option. Makes however sense when you say it since the BS2500 could handle booth communication types while the MX 7000 only could take one-way.
    In any case - an interesting problem. Would be interesting to know about if ever solved, which I hope. It's indeed a very nice remote. Miss the two-way communication so I'll probably get me a Beo6 once they have rolled out the software update for BeoSound 5.
    Inflagrante
  • 06-10-2011 8:21 AM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    I think lausvi is right. Must be the STDBY button. Hide your BL5000, activate your BS7000 manually and get your BL5000. It should set the BS7000 to standby without pressing a button, because it sends a STDBY command all the time, which results in a STDBY SYSTEM command. I had a similiar problem with a BL1000 years ago. It was the VOLUME UP button, which can get dangerous - for the speakers....
    Stefan
  • 06-12-2011 5:31 AM In reply to
    • Noah
    • Switzerland
    • Posts 120
    • Silver Member
    Hello guys
    Nope. The 5000 sets the Beosystem 7000 not to stand-by when I put the batterie in! I don't thinit is the stuck stand-by button![:'(] But when I put the battteries in the Beolink sends a command but the Beomaster does not react.
    So I have no idea what is wrong with that remote.Angry Makes my angry!!;-)
    Noah
  • 06-12-2011 8:00 AM In reply to
    Start from the beginning. Set your BM7000 in option 1 (if that's the only set you have without connected to a Beovision etc)
    So, take another remote (Beo4 eg), and set the BM7000 to A-OPT 1.
    Noah:
    Ok, checked with a camera? Could be an instruction from the Beolink 5000 asking for status information from the BM7000.
