Latest post 05-31-2011 4:50 PM by kallasr. 4 replies.
Page 1 of 1 (5 items)
  • 05-31-2011 11:43 AM
    Av2 Expander Part number 8089111
    Just seen one of these on e-bay and I'm wondering if it would work with an RF Avant VCR. The manual seems to point to it being for MX Tv's but then a previous version of this expander worked with Avants as well by setting the AV Socket to Video Tape 2
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 05-31-2011 11:49 AM In reply to
    Re: Av2 Expander Part number 8089111
    To sue this expander the AV socket has to be set to Expander in the menu of the TV. This is only possible with certain MX/LX televisions.
  • 05-31-2011 3:30 PM In reply to
    Thanks blackrix - saved me an expensive mistake probably - there is no expander in the menu so will leave will alone.
    Thanks again, always good to have this forum to refer too if in doubt
  • 05-31-2011 4:33 PM In reply to
    • Guy1680
    • Top 500 Contributor
    • Joined on 08-18-2007
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    I think it may be useful and work with the Avant.  From the manual for my Beovision 3:
    AV 2 Expander
    The optional AV 2 Expander accessory is a SCART expander for connection of non-Bang & Olufsen equipment, such as decoders, game consoles, and cameras to the DECODER socket on your television. Use a 21-pin cable to connect one plug to the socket marked TV on the Expander box, and connect the other plug to the socket marked DECODER on the television. Remote control operation of equipment connected via the AV 2 Expander is not possible.
    I have an AV2 expander but have not tried it with my TV.  Sadly I don't have time to try it before that auction ends!
  • 05-31-2011 4:50 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Just buy it, test it, tell us, if it does not work, sell it for 1 Euro less...
    -> worth a try - I would say! <-
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
