Hi all,
I have both a Beocenter 9500 and Beocord 7000 where the tape decks no longer rewind, do i need to change belts? if so, where is the best place to obtain or should i just suck it up and pop into my local stealer?!
Regards
Ray
If you can hear the motor running but the tape doesn't move, it's most likely a belt problem.Most of the autoreverse decks will need new belts now.I can supply new belts if you need.
Thanks Martin,
Both decks have exactly the same problem, they play and fast forward but no reverse.
If you think they need new belts then yes please can i buy some!
Best regards
It definitely sounds like a belt problem.I take it, you have tried different tapes ?
You have a PM.
