Latest post 05-31-2011 2:29 PM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 05-31-2011 8:27 AM
    • RayTheWash
    • Top 500 Contributor
    • Joined on 04-16-2007
    • South East London
    • Posts 93
    Tape deck problems
    Hi all,
    I have both a Beocenter 9500 and Beocord 7000 where the tape decks no longer rewind, do i need to change belts? if so, where is the best place to obtain or should i just suck it up and pop into my local stealer?!
    Regards
    Ray Smile
  • 05-31-2011 10:03 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Tape deck problems
    If you can hear the motor running but the tape doesn't move, it's most likely a belt problem.
    Most of the autoreverse decks will need new belts now.
    I can supply new belts if you need.
  • 05-31-2011 2:22 PM In reply to
    • RayTheWash
    • South East London
    • Posts 93
    Thanks Martin,
    Both decks have exactly the same problem, they play and fast forward but no reverse.
    If you think they need new belts then yes please can i buy some!
    Best regards
    Ray
  • 05-31-2011 2:29 PM In reply to
    • Dillen
    • Posts 5,008
    It definitely sounds like a belt problem.
    I take it, you have tried different tapes ?
    You have a PM.
