Latest post 05-30-2011 9:06 PM by BeoBoo. 3 replies.
Page 1 of 1 (4 items)
  • 05-30-2011 11:13 AM
    • BeoBoo
    • Not Ranked
    • Joined on 06-16-2010
    • Petaluma, CA
    • Posts 4
    Beogram RX Turntable
    I recently acquired an RX on Ebay which wasn't mechanically functioning. Removing the bottom panel I found one of the wires leading to the touch control pad had seperated from its terminal, a simple soldering and it was good to go. It now works as supposed to except for one quirk. When pressing 33 or 45 rpm the tonearm goes to where it supposed to, drops to the record but then wants to return back to its starting position. Checking the arm movement there wasn't any resistance or mechanical interference, it seems gravity is pulling it back. The tonearm is properly balanced and set to 1.5g, the odd antiskating appears fixed at the factory so I didn't mess with it. A service manual for this deck would also be very helpful. SmileAny help on this is most appreciated.
  • 05-30-2011 1:07 PM In reply to
    Re: Beogram RX Turntable
    First thing, open the deck, clean and oil/grease all moving parts, clean the switches, check/change caps.
    There is a manul onsite for silver and gold members.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 05-30-2011 1:15 PM In reply to
    Check all three transit screws are fully undone.
  • 05-30-2011 9:06 PM In reply to
    • BeoBoo
    • Not Ranked
    • Petaluma, CA
    • Posts 4
    Thanks for all the suggestions!Yes -  thumbs up
