hello all,
I'm desperately looking for the Bang and Olufsen Sensor (type no. 2001) for the Beomaster 5500 - it allows you to control the unit via the MCP from a greater distance or another part of the house.
I'm currently renovating and this is the perfect time to run cables - I'm hoping to control the system in my living room from the dining room via the sensor, with the secondary set of speakers from the beomaster in the dining room to enjoy the results - eventually these will be upgraded to pentas when I can afford it.
does anyone have one of these sensors knocking about? it really will make all the diference to my system... Failing that does anyone know what kind of cable it would take - that way I can put the walls back together and still carry on searching!
many thanks in advance to everyone for taking the time to read this - all advice gratefully received!
