Latest post 05-27-2011 2:34 AM by Sigmund. 1 replies.
Page 1 of 1 (2 items)
  • 05-27-2011 2:09 AM
    • zor38
    • Not Ranked
    • Joined on 05-27-2011
    • Posts 1
    Beosound Overture
    Hi everybody
    I have owned an Overture since new which is about 20 years old. It has had very little use over the years. My problem is that when trying to play a cd the disc spins a few times and then stops. I have cleaned the face of the laser but it does not make any difference.
    Any advice or help would be gratefully received
    Zor38
    Filed under:
  • 05-27-2011 2:34 AM In reply to
    • Sigmund
    • Not Ranked
    • Joined on 06-20-2007
    • Norway
    • Posts 46
    • Silver Member
    Re: Beosound Overture
    The same happened to my Ouverture. The whole CD mechanism needed to be replaced.
    In the beginning it only affected a few CDs, and my workaround was to copy them and use the copy instead.
    Sigmund
