Latest post 05-23-2011 9:54 AM by chartz. 5 replies.
Page 1 of 1 (6 items)
  • 05-21-2011 5:05 AM
    Serious bargain near Ruthin in the UK
    http://cgi.ebay.co.uk/JOB-LOT-BANG-OLUFSEN-STEREO-EQUIPMENT-WP-/350460851136?pt=UK_AudioTVElectronics_HomeAudioHiFi_Turntables&hash=item51991833c0
    Anyone?
  • 05-21-2011 9:59 AM In reply to
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Re: Serious bargain near Ruthin in the UK
    Don't think it's that much of a bargain to be honest!
    Cheers
    Nigel
  • 05-21-2011 11:17 AM In reply to
    About right I would say - especially as not tested - the S45s look a little tired in the tweeter department.
    Purely as an aside, I looked at the top plate of the BG3000 and noticed the small black plug just before the name. I have checked a picture of mine, long since given away, and it had the same. The only other deck with this that I remember was the Beogram 3400 in which the black plug could be removed and a small red LED inserted when the CD4 board was fitted. Why should the 3000 have a similar plug?
  • 05-22-2011 6:16 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    The little dot next to the Beogram 3000 lettering is a lens.
    There is a small lamp underneath that lights up in orange color (neon) when the
    tonearm is moving at start/stop/lift.
    On the Beogram 3400 there's nothing under the lens.
    There may be something if the quad module is installed though, I never saw one with the module.
  • 05-22-2011 7:09 AM In reply to
    I had never noticed that on mine! Big Smile
  • 05-23-2011 9:54 AM In reply to
    • chartz
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Peter :
    My Beocenter 3500 has it too: it lightens up when auto cueing is running.
    Jacques
