Latest post 05-25-2011 3:18 AM by HuschPusch. 11 replies.
Page 1 of 1 (12 items)
  • 05-14-2011 5:50 PM
    BeoCom 6000 Base Station
    Hello,
    I have a great problem:
    I use a beocom 6000 and I was very satisfied with this phone. Two weeks ago my daughter was not so careful with the phone and now it’s damaged. I bought a used phone and tried to connect it with the base station.
    During the connection the phone asked me about a PinCode. I changed the default code but I forgot it. Is there any possibility to reset the base station to the factory settings without using the phone?
    I hope you can help me.
    Thank you very much in advance.
    Roger
  • 05-15-2011 5:09 AM In reply to
    Re: BeoCom 6000 Base Station
    I'd take it into your local dealer, one a 5 minute job. Not sure if you can do it without a handset, perhaps there is away...anyone???
  • 05-16-2011 11:06 AM In reply to
    Thanks you very much for the advise.
    I called my local dialer and he told me that I have to change the complete board. There is no possibilty to reset the pin. Wow!
    Roger
  • 05-17-2011 4:59 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    I thought I had changed my pin code, but later it didn't work. I tried the default code "0000" and that did it! Try it, before you hand in the hand set.
  • 05-18-2011 9:01 AM In reply to
    Thanks a lot, but it doesn't work.
    Roger
  • 05-18-2011 12:07 PM In reply to
    This is probably a "long shot" but what part of your original (broken) phone no longer works? Could you make the broken phone work using the working phone - reset the pin, then put the working phone back together?
    Stoobie
  • 05-18-2011 5:52 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    It may not need a new circuit board yet!  If too many handsets have been added to a base station, it will ask for a PIN.
    Sometime in the past, could your base have had other handsets added to it?  Is there a way you could 'remove' them by using your working handset?
    Can't hurt trying.
    Andy T.
    Poor me, never win owt!
  • 05-23-2011 7:38 AM In reply to
    Thank you very much, but only one headset was connected to the base station! So I have no headset wirh a connection to the base station!
    Roger
  • 05-23-2011 7:40 AM In reply to
    Thanks a lot. It's a pitty, but the old headset is in the trash.
    Roger
  • 05-24-2011 2:16 PM In reply to
    I think your dealer can't reset the PIN, but Bang & Olufsen might be able to reset it!
  • 05-24-2011 3:25 PM In reply to
    Saw this on eBay LINK
    Can't vouch for the service but saw it when perusing last night.
    Stoobie
  • 05-25-2011 3:18 AM In reply to
    Thanks.
    I wrote to the support of B&O in Denmark two weeks ago.
    The answer was:
    "Thank you for your request. Below is a summary of your request and our response.
     Subject
    Connection of additional handset
     Discussion Thread
     Response  16/05/2011 11.28 AM
    Dear Mr. Maehr,
    We are sorry that your BeoCom 6000 handset became defective, and that you cannot make registration of your new handset work with your base station.
    If a PIN-code has been activated in the telephone, and you do not remember this, it will be necessary that you contact your Bang & Olufsen dealer in order to obtain help in opening it again. This is not something we can handle by e-mail.
    Kind regards,
    Bang & Olufsen a/s
    Customer Service"
    Roger
