Maybe the new software update for blu-ray in BeoVison 7 will solve the problem.
New firmware: 110324 (relased 27/4)
The new firmware will help the blu-ray playability with some titles:
- “Inglorious Basterds”
- “OSS 177”
- “Robin Hood BD”
- Disney Blu-ray and DVD
- Replay of “Avatar” may give a warning message about software update.
- Audio interference when playing “Toy Story 2” and “Lords of the Rings Trilogy”
- Intermittent picture freeze seen on “Sherlock Homes” and “Toy Story”
The update is possible with a CD-ROM with the firmware. Contact your dealer if you need the update with CD-ROM.
You can also update with ethernet-cable connected:
1. Before you switch on the TV, insert the Ethernet cable in the TV.
2. TV must be in standby, no disc in the loader. Press /DVD/, wait until 'NO DISC' is displayed on the screen and make sure the loader is closed.
3. Enter the Setup menu on your Beo5 by pressing /DVD setup/ (if you use a Beo4 press /YELLOW/ and then /8/).
4. Select 'ADVANCED' and press /GO/.
5. Select 'SOFTWARE UPDATE'. The Blu-ray player now automatically searches for new software, and the new software will be displayed on the screen.
6. Press /GREEN/ on Beo5 to start the software update (If you use a Beo4 press /GREEN/ twice) and follow the instructions displayed on the screen.
