Latest post 05-11-2011 4:36 PM by Peter. 7 replies.
Page 1 of 1 (8 items)
  • 05-08-2011 6:39 PM
    beosystem 7000 and loudspeakers
    What are  the best loudspeaker with beosystem 7000? Recently beolab 6000 are ok or not?
  • 05-09-2011 3:33 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: beosystem 7000 and loudspeakers
    You have a choice of either active or passive speakers with the BeoSystem 7000.. so take your pick!  Yes -  thumbs up
    What is your budget is the first question.  Secondly (and just as important), what kind of music do you listen to - and at what volumes?
    Once we have that info, the suggestions will come flooding in!
    Smile
  • 05-10-2011 11:42 AM In reply to
    I listen to all kinds of music at high volumes. My budget is max 1000
  • 05-10-2011 4:59 PM In reply to
    I would get a pair of Pentas. I used a pair with my 7000 system for years and was very happy with them. They go loud, have plenty of bass and match the system. If being critical, they lack a bit of top end fizz and the bass is not as detailed as speakers with a big bass driver. Still have the Pentas though !
  • 05-10-2011 6:23 PM In reply to
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    I would go for a pair of MS150. I am very privaliged to own the actual pair photographed in the link. They were extensively refurbished several years ago and sound sublime. The inbuilt subwoofers really do move a significant amount of air!
    The only problem is they're like hen's teeth and will almost certainly need to be refurbed if they haven't been already.
    I haven't actually heard a pair of 6000 but I have heard them described as "rubbish" (as main speakers) by someone whose judgement I trust!
    Good luck!
    Cheers
    Nigel
  • 05-10-2011 6:43 PM In reply to
    I'd go for Penta's
    Regards
    Michael
    BV5, BV Avant, MX4000, MX1500
    BS 7000, BS 5500
    Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu
    BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2)
  • 05-11-2011 3:31 PM In reply to
    • henrik
    • Top 200 Contributor
    • Stockholm, Sweden
    • Posts 299
    h1npw:
    Do you use them with a Beomaster 7000? Can it handle the MS150s? I've had some problem with my bm7000-m150 combo, that's why I'm asking. :-)
  • 05-11-2011 4:36 PM In reply to
    I have used them with a 7000 system and MS150s work fine. They are however very big and I don't think even their mother would call them pretty!
