1st March February 2012
Latest post 05-08-2011 2:53 PM by Daniel. 13 replies.
05-07-2011 3:42 PM
Ferdinand
- Joined on 05-04-2008
- Malmö, Sweden
- Posts 159
Viewing hours on MX 6000 with Beo4-remote
As I am still trying to sell my MX6000 to clear some space I have it for sale now for 500 SEK
One of the questions that I have received is ''how many hours has it been on''
I searched the forum and found some tips and tricks, but none did work unfortunately.
So: how can I check the viewing hours on my MX6000-Beo4 , I have Beo4 remote available.
Thanks for he help in advance
BS9000, Beolab 3000, Beocenter 7002, RL60.2, beo4, BV10
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Re: Viewing hours on MX 6000 with Beo4-remote
I'm pretty sure it doesn't have any such counters.
Bentleyman
- Joined on 12-29-2008
- Rochdale
- Posts 367
tournedos:
What about an MX4000..? Are there no service counters on those either..?
Regards
Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2, RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500, BL 5000, Beo4 (x2), BL 1000 (x2)
Bentleyman
- Rochdale
- Posts 367
Michael
BS 7000, BS 5500
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
tournedos:
Why not? My LX 5500 has it, and it's basically the same TV.
stotty1111
- Joined on 12-16-2007
- UK / France - Nth Worcestershire/Finistere
- Posts 924
as does mx5500
use menu>0>0>play(go)
get a software version and 3 item list
Above using a bl1000 remote
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
tournedos
- Finland
- Posts 5,808
Well I have an MX6000IT-Beo4 (Mk.I) myself, and the menu-0-0-go page only shows the software version (3.10).
The
first page of the service mode (menu-1-1-go) shows the last error code,
the serial number of the set, and an 8-digit code that doesn't advance
(the service manual says it should be the 4 digit type code, but that
doesn't match on mine).
Also, went to try the LX6000 I have in storage. Menu-0-0-go again only shows the software version (1.0). This one doesn't allow entering the service menu by the remote (shows the channel list instead).
The earlier models are on a slightly different chassis, so apparently the service counters were dropped inbetween for whatever reason.
stotty1111
- Posts 924
Set type 3263
no 0815****
shows
software variant 1.50 S
A: 2429
B: 0603
C:
However don't know what they indicate
Menu allows only timer, pl link, scart 1 and scart 2 adjustments
tony
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
If you told them the truth you could only put buyers off. You will be better saying "I honestly don't know".
At £50 or thereabouts and still working, what is to worry about?????
Ferdinand
- Malmö, Sweden
- Posts 159
Hi Graham and others,
Thanks for the feedback. I am with you -Graham- as I do not understand either why such specific info is requested for just a 50 euro / 500 SEK tv.
It turns out to be quite difficult to sell, so I now chosen to sell the TVcheap and to keep the remote (Beo4).
If it will not sell this time (on blocket, local eBay franchise) I will keep the tv for WII etc. But at this point the TV is a 42kg 'stand in the way'. (is that how to say it? or is it as bad as 'I thank you of the bottom of my heart and also my wife's bottom')
Daniel
- Svinarp, Sweden
- Posts 1,284
stotty1111:
Set type 3263
no 0815****
shows
A: 2429
B: 0603
C:
tony
There you go! 24 290 hours whatching telly, 6 030 in link mode.
http://forum.beoworld.org/forums/p/19575/145911.aspx#145911
tournedos
- Finland
- Posts 5,808
Daniel:
...and the same thread also gives another data point saying that it does not work on a MX7000 (which is the same Unity 2 chassis as MX/LX 6000/4000). Your 5500's are Unity 1.
And I also would tell buyers who need to know stuff like that from a 10+ years old 50€ television to sod off
Daniel
- Svinarp, Sweden
- Posts 1,284
tournedos:
Daniel:
OK!
I had to check the hours again, 23 790. Almost 1 000 days.
Page 1 of 1 (14 items)
