Latest post 05-08-2011 2:53 PM by Daniel. 13 replies.
Page 1 of 1 (14 items)
  • 05-07-2011 3:42 PM
    Viewing hours on MX 6000 with Beo4-remote
    As I am still trying to sell my MX6000 to clear some space I have it for sale now for 500 SEK
    One of the questions that I have received is ''how many hours has it been on''
    I searched the forum and found some tips and tricks, but none did work unfortunately.
    So: how can I check the viewing hours on my MX6000-Beo4 , I have Beo4 remote available.
    Thanks for he help in advance
    BS9000, Beolab 3000, Beocenter 7002, RL60.2, beo4, BV10
  • 05-07-2011 4:28 PM In reply to
    Re: Viewing hours on MX 6000 with Beo4-remote
    I'm pretty sure it doesn't have any such counters.
    -mika
  • 05-07-2011 4:53 PM In reply to
    tournedos:
    What about an MX4000..? Are there no service counters on those either..?
    Regards
    Michael
    BV5, BV Avant, MX4000, MX1500
    BS 7000, BS 5500
    Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu
    BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2)
  • 05-07-2011 4:58 PM In reply to
    Same chassis, so no.
    -mika
  • 05-07-2011 5:01 PM In reply to
    Thanks for info.
    Michael
    BS 7000, BS 5500
  • 05-08-2011 6:41 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    tournedos:
    Why not? My LX 5500 has it, and it's basically the same TV.
  • 05-08-2011 7:45 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    as does mx5500
    use menu>0>0>play(go)
    get a software version and 3 item list
    Above using a bl1000 remote
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 05-08-2011 8:09 AM In reply to
    Well I have an MX6000IT-Beo4 (Mk.I) myself, and the menu-0-0-go page only shows the software version (3.10).
    The first page of the service mode (menu-1-1-go) shows the last error code, the serial number of the set, and an 8-digit code that doesn't advance (the service manual says it should be the 4 digit type code, but that doesn't match on mine).
    Also, went to try the LX6000 I have in storage. Menu-0-0-go again only shows the software version (1.0). This one doesn't allow entering the service menu by the remote (shows the channel list instead).
    The earlier models are on a slightly different chassis, so apparently the service counters were dropped inbetween for whatever reason.
    -mika
  • 05-08-2011 9:23 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Set type 3263
    no 0815****
    shows
    software variant 1.50 S
    A: 2429
    B: 0603
    C:
    However don't know what they indicate
    Menu allows only timer, pl link, scart 1 and scart 2 adjustments
    tony
  • 05-08-2011 10:56 AM In reply to
    If you told them the truth you could only put buyers off. You will be better saying "I honestly don't know".
    At £50 or thereabouts and still working, what is to worry about?????
    Regards Graham
  • 05-08-2011 12:11 PM In reply to
    Hi Graham and others,
    Thanks for the feedback. I am with you -Graham- as I do not understand either why such specific info is requested for just a 50 euro / 500 SEK tv.
    It turns out to be quite difficult to sell, so I now chosen to sell the TVcheap and to keep the remote (Beo4).
    If it will not sell this time (on blocket, local eBay franchise) I will keep the tv for WII etc. But at this point the TV is a 42kg 'stand in the way'. (is that how to say it? or is it as bad as 'I thank you of the bottom of my heart and also my wife's bottom')   Laughing
  • 05-08-2011 2:20 PM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    stotty1111:
    Set type 3263
    no 0815****
    shows
    A: 2429
    B: 0603
    C:
    tony
    There you go! 24 290 hours whatching telly, 6 030 in link mode.
    http://forum.beoworld.org/forums/p/19575/145911.aspx#145911
  • 05-08-2011 2:44 PM In reply to
    Daniel:
    ...and the same thread also gives another data point saying that it does not work on a MX7000 (which is the same Unity 2 chassis as MX/LX 6000/4000). Your 5500's are Unity 1.
    And I also would tell buyers who need to know stuff like that from a 10+ years old 50€ television to sod off Big Smile
    -mika
  • 05-08-2011 2:53 PM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    tournedos:
    Daniel:
    OK!
    I had to check the hours again, 23 790. Almost 1 000 days.
