Latest post 05-04-2011 9:33 AM by Hiort. 1 replies.
Page 1 of 1 (2 items)
  • 05-02-2011 10:56 AM
    • mondo
    • Not Ranked
    • Joined on 11-10-2009
    • Posts 3
    V+ connection to Beovision7
    Can anyone help me to connect my Virgin Media V+ to my Beovision 7. I currently use a scart connection but this does not give HDTV.
    If I connect using an HDMI cable with DVI adapter, no connection. I can get an HD picture with a PBR connection, but no sound. I also lose the V+ menu contrls through my Beo4 remote
    Any ideas??
  • 05-04-2011 9:33 AM In reply to
    Re: V+ connection to Beovision7
    Have you checked the setting in your Virgin box, to make sure it sends the sound over the HDMI?
    If you use PBR, you must transfer the sound separately to BV7 from the digital output (optical) from the Virgin box to a digital input on the BV7 (SPDIF).
    For this you need a converter to go from the optical (Toslink) type of cable from the Virgin to the SPDIF cable that BV7 accept. Such convcerters are quite  cheap. Drawback is that they need power supply.
    /C
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
