I wonder if it's possible to change to Aux on a Beocenter 9500 with the remote Beolink 1000?
I can switch to radio, tape, cd, phono without any problem but I can't switch to the aux.
Try SHIFT+RADIO.
If you don't have a Beovision in the same installation, the easiest way is to program the BC9500 to Option 2 and then you can just use TV for AUX.
-mika
Shift + Radio worked.
how do I program my BC9500 to Option 2?
Try [SOUND]+[2]+[STORE].
as aqbove, but with the bc in standby mode, the red light on the bc should flash onceif the command is accepted
salut
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
thanf for your help!
