Latest post 05-01-2011 4:26 AM by covent. 5 replies.
Page 1 of 1 (6 items)
  • 04-30-2011 1:30 PM
    • covent
    • Not Ranked
    • Joined on 03-12-2011
    • Stockholm, Sweden
    • Posts 26
    • Silver Member
    Beolink 1000 and Aux on Beocenter 9500
    I wonder if it's possible to change to Aux on a Beocenter 9500 with the remote Beolink 1000?
    I can switch to radio, tape, cd, phono without any problem but I can't switch to the aux.
  • 04-30-2011 1:43 PM In reply to
    Re: Beolink 1000 and Aux on Beocenter 9500
    Try SHIFT+RADIO.
    If you don't have a Beovision in the same installation, the easiest way is to program the BC9500 to Option 2 and then you can just use TV for AUX.
    -mika
  • 04-30-2011 2:00 PM In reply to
    • covent
    • Not Ranked
    • Stockholm, Sweden
    • Posts 26
    • Silver Member
    Shift + Radio worked.
    how do I program my BC9500 to Option 2?
  • 04-30-2011 2:38 PM In reply to
    • psand
    • Not Ranked
    • Joined on 05-05-2010
    • Stockholm, Sweden
    • Posts 48
    • Gold Member
    Try [SOUND]+[2]+[STORE].
  • 04-30-2011 3:10 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    as aqbove, but with the bc in standby mode, the red light on the bc should flash onceif the command is accepted
    salut
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 05-01-2011 4:26 AM In reply to
    • covent
    • Not Ranked
    • Stockholm, Sweden
    • Posts 26
    • Silver Member
    thanf for your help!
