Latest post 05-04-2011 9:59 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 04-30-2011 10:39 AM
    Veneer colour codes?
    Some time ago there was a BM6000 Quad on eBay on which someone had painted the veneer black. I asked the seller if he knew what type of veneer it was under the paint - he answered it should be Teak, because the serial number said so.
    Is this really part of the serial number? Somehow I doubt it.
    If it's true, what colour should this be? There's nothing left of the original veneer and I want to replace it...
  • 04-30-2011 11:54 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Veneer colour codes?
    It's not part of the actual serial number but often found stamped on the same label as f.e. P2 or P3.
    It's not easy to say what the original finish was on the Beocenter 1800 since there are
    no obvious codes but it could easily have been white.
  • 05-04-2011 8:47 AM In reply to
    So if there's no code it is white? I now remember seeing those stamps (P2 etc.) on other units. As I bought this Beocenter along with a original white Beocord 2200 you should be right...
    Great! That makes replacement all the easier. I'm sure I have some white adhesive foil somewhere.
  • 05-04-2011 9:59 AM In reply to
    • Dillen
    • Posts 5,008
    It's not a rule that it's white if there is no veneer coding.
    It is just possible.
