Sounds extremely weird. If it reacts at all, it should react to all commands. Are you sure the problem is not with your Beo4? Or in your programming of the LC2?
Otherwise, try disconnecting the LC2 from mains, and wait a while - then reconnect. This should reboot the microprocessor in the LC2.
