Latest post 05-02-2011 4:33 AM by Kokomo. 6 replies.
Page 1 of 1 (7 items)
  • 04-30-2011 5:50 AM
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    LC2 faulty?
    One of my LC2s has stopped responding to beo4 buttons 1-5, but still operates with buttons 6-9. Dome touch on/off and dimmming work fine, so other than the obvious conclusion that there's an unrepairable fault with the unit, does anyone have any suggestions?
  • 04-30-2011 2:49 PM In reply to
    • psand
    • Not Ranked
    • Joined on 05-05-2010
    • Stockholm, Sweden
    • Posts 48
    • Gold Member
    Re: LC2 faulty?
    Sounds extremely weird. If it reacts at all, it should react to all commands. Are you sure the problem is not with your Beo4? Or in your programming of the LC2?
    Otherwise, try disconnecting the LC2 from mains, and wait a while - then reconnect. This should reboot the microprocessor in the LC2.
  • 05-01-2011 10:45 AM In reply to
    • Kokomo
    • Spain
    • Posts 618
    Re: LC2 faulty?
    psand:
    Thanks for that. Yes I agree it is weird and I'm sure the problem is not with the Beo4 as it operates other LC2s fine. I cannot program it to the numbers 1-5 although the other LC2s will.
    Will try your suggestion, although here in Spain, power cuts will probably do it for me on about a weekly basis!
    Thanks again.
  • 05-01-2011 12:07 PM In reply to
    Re: LC2 faulty?
    Do you have bought a plasma screen recently? That could also be the problem
  • 05-01-2011 12:25 PM In reply to
    Re: LC2 faulty?
    Maybe you can try to reprogram the lightprograms 1-5, it could be that for program 1-5 the LC2 is programmed to switch off in one way or the other.
  • 05-02-2011 4:30 AM In reply to
    • Kokomo
    • Spain
    • Posts 618
    Re: LC2 faulty?
    1983beo:
    No, but thanks for the suggestion - appreciated.
  • 05-02-2011 4:33 AM In reply to
    • Kokomo
    • Spain
    • Posts 618
    Re: LC2 faulty?
    Blackrix:
    Will certainly give that a go. Thanks.
    In the absence of any success I may just have to accept that something in the internal electronics has caused this to happen. In which case I think I'm stuck!
    Thanks again.
