Latest post 05-03-2011 11:31 PM by Jonathan. 8 replies.
Page 1 of 1 (9 items)
  • 04-29-2011 6:32 PM
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    BeoLab 4500 - Remove power cable
    Hello,
    The power cable seems to be covered where it enters the rear of the speaker.
    Anyone know how to remove the power cable from the speaker itself?
    Thanks beoaus.
  • 04-29-2011 7:44 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: BeoLab 4500 - Remove power cable
    The power cord is soldered on so you will have to get inside to get it out.
    I haven't been inside my amps for a while, but I think you need to access it from the back via torx driver.
    Evan
  • 04-30-2011 4:18 AM In reply to
    • beoaus
    • Posts 445
    I checked you are correct. So I had to cut the cords at the power socket end.
    The speakers are being checked out after being in a room that flooded, lots of moisture and water. I wonder if the speaker cones are rubber or paper?
    I am crossing my fingers...
    beoaus
  • 04-30-2011 7:40 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    I am pretty sure the woofers are paper.
    I need to go and replace my power cords too, as the last owner cut them in half and as a temporary solution, I just added some new wall terminations and used extension cords.
    Evan
  • 04-30-2011 8:18 PM In reply to
    • Dennis
    • Top 500 Contributor
    • Joined on 02-01-2009
    • Denmark
    • Posts 172
    • Gold Member
    The cones are made out of plactic, and the dust-caps out of rubber, so there shouldn't be any damage to the drivers. Smile
    - Dennis
    I was borned with a Beolink 1000 in my hand!
    Ever seen a Beomaster 6001? I have one! Look here.
    Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
    Wish list: Beolab 2,
  • 05-03-2011 12:48 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Loudspeaker:
    - Dennis
    That's great news! I have only had the frets off once or twice, and it shows! Laughing The best part, for all of us, is that the drivers also have rubber surrounds!
    Evan
  • 05-03-2011 8:08 PM In reply to
    beoaus:
    Everything ok??
    My B&O: 2009 Catalogue and Pricelist
  • 05-03-2011 9:23 PM In reply to
    • beoaus
    • Posts 445
    Yes, the speakers are ok.
    The house has damage, and some contents destroyed. Most of the B&O equipment is fine. Its a process though.... Lots of people are worse off.
    thanks, beoaus.
  • 05-03-2011 11:31 PM In reply to
    ...I was more concerned for you and your family!
