Latest post 05-21-2011 5:34 PM by Step1. 6 replies.
Page 1 of 1 (7 items)
  • 04-19-2011 2:39 PM
    • anagnost
    • Not Ranked
    • Joined on 12-16-2007
    • Ioannina, Greece
    • Posts 4
    Beogram 4000 - Doesn't move across
    Hello all,
    after a a period of some months, I tried to play some records on my Beogram 4000 with no success.
    The tone arm does not move across!  I removed the aluminium plates and I saw that the motor doesn't turn.  I measured the voltsge on the cable motors and is 0 Volts?
    Do you have any idea about this?
    Thank you very much in advance.
    Vassilis Anagnostopoulos
    Beogram 4000 - Type 5215 - No 215498
  • 04-21-2011 2:43 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: Beogram 4000 - Doesn't move across
    I assume all other signs of life seem ok? What happens when you press the [on] key.
    I always look at the transistor H bridge (the four metal-can transistors with accompanying drivers) if the motor shows no signs of life. It is a good place to start! if they are ok then check control signals, supplies etc but this deck is a complicated beast and not the best project to start if you are initially stumped!
    The service manual has a good fault finding chart so join up and download!
    Olly.
  • 04-21-2011 4:06 PM In reply to
    • anagnost
    • Not Ranked
    • Ioannina, Greece
    • Posts 4
    Hello Olly,
    and thanks for the reply.
    When I press the [ON] key, absolutely nothing happens.  On the other hand when I press the [33] key then the plate rotates normally.
    I already have the service manual of the deck and I have checked the fault finding chart.  Unfortunatelly my knowledge on electronics is very limited and I have stacked.
    Can you tell me where is this transistor H bridge located? How can I check if this is working properly?
    Thanks in advance
    Vassilis
  • 05-19-2011 4:39 PM In reply to
    Maybe it's a blown fuse? They are placed under the greyish plastic cover in the left upper corner.
  • 05-19-2011 6:22 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    ok try carefully advancing the carriage by turning its screw wheel, say, to just before the start of a 33 record (you can do this without a record or cartridge ideally!) and then plug in, see what happens.
    Lights? Main motor? Anything?
    Olly.
  • 05-21-2011 4:35 PM In reply to
    • anagnost
    • Not Ranked
    • Ioannina, Greece
    • Posts 4
    I moved the carriage by turning the screw as you said and then plug-in, but absolutely nothing is happening!
    Of course if I press again the [33] key then the plate rotates and the strobe light flashes.
    @filip_kgh
    The fuses are fine!
  • 05-21-2011 5:34 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Sorry I seem to have sent you on a bit of a goose-chase there... I would check that the on switch is actually doing it's job by checking continuity otherwise you really will have to follow the fault chart & diagram I think...
    Olly.
