Brendan:
I just had a look under the platter and you are correct! The point for 30cm is easily accessed but proper access to the 17cm point is obscured by the lid assembly.
If I can find out how to remove the lid assembly that would be most helpful.
Many thanks for your help Soren. Regards, Brendan.
It is possible to do the adjustment with the deck closed but more convenient with it open.
The deck opens like a clamshell, with the hinge on the left hand side and the fixing clip under the right.
Remove the platter and gently push the arm carriage to the left, as far as it will go.
Place the deck with the right side overhanging the edge of a table or worktop.
Remove two screws (cross head) under the right edge.
With the dust cover raised, lift the right side to open the deck. You may have to ease the arm carriage slightly to clear the top of the deck.
Clipped in the rear left corner you will find a prop (Like a hood/bonnet stay) and a hole to fix it.
Move the arm carriage back to the right and replace the platter.
Make the 17cm adjustment as described (Beware live mains!!!!)
Check 30cm setting with an album. It may now be ok and if so you can re-assemble.(Beware, not all albums are the same size!!) If not, proceed to next line.
Remove the platter , make 30cm adjustment.
Replace platter and check that all ok.
Remove platter, move arm carriage to left.
Re-assembly is the reverse of dismantling!
Good Luck
