I'm sure the antenna has nothing to do with it.
It may have been just a temporary confusion in the processor, caused by some random event like a tiny AC power drop. If it happens again, try unplugging from mains for a while so it will reset properly.
If the erratic behaviour continues, it may be contact problems in the connectors between the CPU module and the front panel, or the CPU announcing it might want some capacitors replaced.
