Latest post 04-04-2011 8:08 PM by Eugene. 16 replies.
Page 1 of 1 (17 items)
  • 04-03-2011 10:10 PM
    My Homemade Beomaster 4400 Preset Cover
    After seeing the threads and posts about the elusive preset cover for BM 4400s, I decided to make my own version.  As you will see, I took a few liberties from the original design.  I used a cassette case as the donor.  Here it is being cut to rough dimension with a razor saw.
    I used double sided tape to attach the rough cut cover to a flat piece of hardwood.  This make it easier to handle during sanding and polishing.
    I used 400 grit and then 1500 grit wet sandpaper to level the cover and thin it to 2.8mm.
    This is the cover still attached to the wood, after flat sanding.
  • 04-03-2011 10:20 PM In reply to
    Re: My Homemade BG 4400 Preset Cover
    Here is the cover after polishing the edges.  It is alot easier to do the edges while the cover is still attached to the block of wood.
    These are the two tabs that I cut, ready to be glued to the cover.
    The tabs, glued in place.  I used blue painters tape to make guides to locate the tabs.  The tabs are a attached a bit below center.  this is so I can "hook" the tabs allowing them to be locked onto the 4400 receiver.  I used cyanoacrylate glue (super glue).
    Here is where I got so involved that I forgot to take pictures of the next few steps.  Once the tabs were dried, I cut off the ends of the cover.  I then sanded them square and polished the edges.  I shaped the tabs by rounding the upper corner and slotting the bottom to form a hook.  I used a couple of needle files to do the shaping.  Here is the cover after final shaping, before final polishing.
  • 04-03-2011 10:28 PM In reply to
    This is a closeup of one of the tabs.
    Here is the cover installed on the BM 4400.  The cover hooks on and is very secure, but is easily removed.  the preset slots on my BM 4400 measures 14.1mm, so I wanted something wider than the 14mm of the stock cover.  The cassette case is 16mm wide so it worked fine.  Since I was making this for my use, I wanted to design it how I thought it should have been originally made.  I like how it came out.
    Thanks for looking, and for the help with the specs of the original cover.
    Kevin
  • 04-04-2011 1:57 AM In reply to
    • valve1
    • Top 500 Contributor
    • Joined on 05-27-2009
    • Dublin Ireland
    • Posts 213
    • Gold Member
    Well done and the pictures are great.
  • 04-04-2011 2:38 AM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Yes -  thumbs up
    Great work! Looks very good and the use of a cassette case was really a superb idea!
    Bang & Olufsen - The art of controlling sound, picture and light
  • 04-04-2011 3:50 AM In reply to
    Nice job! Yes -  thumbs up
    Personally I wouldn't bother with the hooks. The tabs on the original cover are straight and it stays on just fine as long as the fit is snug.
    -mika
  • 04-04-2011 3:51 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    I wonder, if B&O had used your hook system if there would be quite so much of a problem these days!
    That is pro work - I am very impressed!
    Olly.
  • 04-04-2011 7:40 AM In reply to
    Superb thread! Great pictures too. I reckon you could start a business making and selling these. 99% are missing and this looks like a perfect answer. Well done.
  • 04-04-2011 9:20 AM In reply to
    tournedos:
    Thanks for the kind remarks!
    After looking at pictures of the original covers, I think relying on a friction fit was the problem all along.  It seems they would eventually get loose, or be so tight as to risk breakage from repetitive removals.  The hooks rely on mechanical fit and can be removed repeatedly without affecting the fit.  Until I saw the pictures of an original cover I assumed they hooked onto the faceplate, and I was quite surprised that they didn't.
    Kevin
  • 04-04-2011 10:15 AM In reply to
    I think the biggest problem with the original design is that the clips are shaped like forks. The idea probably was to have some tension in them keeping the cover tightly on, but that doesn't have much chance of working with that kind of hard plastic and the material strength. Once you break off one of the four small tabs, there's no way the cover will stay on properly any more.
    It apparently wasn't very good quality to begin with either. Mine is clearly warped around the spot where it once was attached to the molding frame.
    -mika
  • 04-04-2011 3:20 PM In reply to
    Great solution. Now I almost can't wait until my original cover will break down......Big Smile
  • 04-04-2011 6:00 PM In reply to
    Oh man, do I like these kind of threads, excellent jobYes -  thumbs up
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 04-04-2011 6:51 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-10-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    beaker:
    Can we first talk someone into making stands for Beovox S45-2s?
    Awesome work, Kevin!
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 04-04-2011 7:08 PM In reply to
    Rich:
    beaker:
    Here, no problems
    http://forum.beoworld.org/forums/t/35659.aspx
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 04-04-2011 7:53 PM In reply to
    A lot of work for a simple little dial cover.
    I am convinced we are all nuts.
  • 04-04-2011 8:00 PM In reply to
    • Rich
    • Posts 1,089
    • Gold Member
    Eugene:
    Well, duh! Yes -  thumbs up
    See if anyone get's this Beavis and Butthead quote:  "Hey, Uncle Charlie.  Sounds like a lot of work to me."
    My wife has been saying that ever since I got the M70s back out.
  • 04-04-2011 8:08 PM In reply to
    Even dumber is the retard (me) who restored several cassette players over the winter but only actually has a few cassettes to play on them.
    But but .. it completes the set.
