        1st March February 2012
	    Latest post 04-04-2011 8:08 PM by  Eugene. 16 replies.
								        04-03-2011 10:10 PM
									        Keiko5
								                - Joined on 03-19-2011
								                - Posts 25
										    My Homemade Beomaster 4400 Preset Cover
										    After seeing the threads and posts about the elusive preset cover for BM 4400s, I decided to make my own version.  As you will see, I took a few liberties from the original design.  I used a cassette case as the donor.  Here it is being cut to rough dimension with a razor saw.
I used double sided tape to attach the rough cut cover to a flat piece of hardwood.  This make it easier to handle during sanding and polishing.
I used 400 grit and then 1500 grit wet sandpaper to level the cover and thin it to 2.8mm.
This is the cover still attached to the wood, after flat sanding.
									        Keiko5
								                - Posts 25
										    Re: My Homemade BG 4400 Preset Cover
										    Here is the cover after polishing the edges.  It is alot easier to do the edges while the cover is still attached to the block of wood.
These are the two tabs that I cut, ready to be glued to the cover.
The tabs, glued in place.  I used blue painters tape to make guides to locate the tabs.  The tabs are a attached a bit below center.  this is so I can "hook" the tabs allowing them to be locked onto the 4400 receiver.  I used cyanoacrylate glue (super glue).
Here is where I got so involved that I forgot to take pictures of the next few steps.  Once the tabs were dried, I cut off the ends of the cover.  I then sanded them square and polished the edges.  I shaped the tabs by rounding the upper corner and slotting the bottom to form a hook.  I used a couple of needle files to do the shaping.  Here is the cover after final shaping, before final polishing.
									        Keiko5
								                - Posts 25
										    This is a closeup of one of the tabs.
Here is the cover installed on the BM 4400.  The cover hooks on and is very secure, but is easily removed.  the preset slots on my BM 4400 measures 14.1mm, so I wanted something wider than the 14mm of the stock cover.  The cassette case is 16mm wide so it worked fine.  Since I was making this for my use, I wanted to design it how I thought it should have been originally made.  I like how it came out.
Thanks for looking, and for the help with the specs of the original cover.
Kevin
									        lausvi
								                - Joined on 04-16-2007
								                - Helsinki - Finland
								                - Posts 498
Great work! Looks very good and the use of a cassette case was really a superb idea!
									    Bang & Olufsen - The art of controlling sound, picture and light
									        tournedos
								                - Joined on 12-08-2007
								                - Finland
								                - Posts 5,808
										    Nice job!
Personally I wouldn't bother with the hooks. The tabs on the original cover are straight and it stays on just fine as long as the fit is snug.
									        Step1
								                - Joined on 07-06-2008
								                - Manchester
								                - Posts 961
										    I wonder, if B&O had used your hook system if there would be quite so much of a problem these days!
That is pro work - I am very impressed!
									        beaker
								                - Joined on 06-14-2007
								                - Posts 526
										    Superb thread! Great pictures too. I reckon you could start a business making and selling these. 99% are missing and this looks like a perfect answer. Well done.
									        Keiko5
								                - Posts 25
										      tournedos:
Nice job!
Thanks for the kind remarks!
After looking at pictures of the original covers, I think relying on a friction fit was the problem all along.  It seems they would eventually get loose, or be so tight as to risk breakage from repetitive removals.  The hooks rely on mechanical fit and can be removed repeatedly without affecting the fit.  Until I saw the pictures of an original cover I assumed they hooked onto the faceplate, and I was quite surprised that they didn't.
Kevin
									        tournedos
								                - Finland
								                - Posts 5,808
										    I think the biggest problem with the original design is that the
clips are shaped like forks. The idea probably was to have some tension
in them keeping the cover tightly on, but that doesn't have much chance
of working with that kind of hard plastic and the material strength.
Once you break off one of the four small tabs, there's no way the cover
will stay on properly any more.
It apparently wasn't very good quality to begin with either. Mine is clearly warped around the spot where it once was attached to the molding frame.
									        Leslie
								                - Joined on 05-07-2009
								                - Netherlands
								                - Posts 2,201
										    Oh man, do I like these kind of threads, excellent job
									    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
									        Rich
								                - Joined on 07-11-2010
								                - Orlando, Florida, USA
								                - Posts 1,089
										      beaker:
Can we first talk someone into making stands for Beovox S45-2s?
Awesome work, Kevin!
									    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
									        Søren Mexico
								                - Joined on 09-13-2007
								                - Mexico city
								                - Posts 1,621
										      Rich:
  beaker:
Here, no problems
http://forum.beoworld.org/forums/t/35659.aspx
									    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
									        Eugene
								                - Joined on 12-17-2008
								                - Posts 589
										    A lot of work for a simple little dial cover.
I am convinced we are all nuts.
									        Rich
								                - Posts 1,089
										      Eugene:
Well, duh!
See if anyone get's this Beavis and Butthead quote:  "Hey, Uncle Charlie.  Sounds like a lot of work to me."
My wife has been saying that ever since I got the M70s back out.
									        Eugene
								                - Posts 589
										    Even dumber is the retard (me) who restored several cassette players over the winter but only actually has a few cassettes to play on them.
But but .. it completes the set.
        Page 1 of 1 (17 items)
