1st March February 2012
Latest post 05-18-2011 5:35 AM by Agent00soul. 12 replies.
04-02-2011 6:42 AM
Chris
- Joined on 05-09-2010
- Last of the Summer Wine Country, Yorkshire, UK
- Posts 195
Beolit 600 Radio - How much?
I am thinking about buying a Beolit 600 Radio in good condition. How much should I be wanting to pay?
Thanks.
Beosound 8, Beotalk 1100, Beocom 4, A8 Headphones, Form 2 Headphones, Apple iPhone 4S, iPod Classic, iPad 1, Sky+ HD, Sony Playstation 3, Jacob Jensen T10, Lutron Rania IR Dual Dimmer/ Accesory dimmer, B+O A9 Keyring (SOLD), Beolit 600 (SOLD), Apple Airport Express, Beo5
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Re: Beolit 600 Radio - How much?
Which model Beolit 600?
1964 one - probably between £50 £ £100
1970 one - probably between £75 & £125
I'm using eBay as a guide here & prices depend on several factors - condition, willingness of the seller to post & quality of the listing.
Like all ebay sales though, there are bargains to be had if you search hard enough.
Chris.
Trigi
- Joined on 01-29-2010
- Ry, Denmark
- Posts 21
Hi Chris.
If u want a radio as good as new, u migth consider this dealer in Denmrk:
http://www.bremdal-radio.dk/bremdal-radio.aspx
-Go to "Classics". There ull find beolit 600´s and others. And they are ok.
If u have trouble whit the language or other things, ill be glad to help u out.
Check it out.
Best regards.
Peter.
Chris
- Posts 195
Well, I bought one from eBay and it arrived damaged. Does anyone know of something that stocks parts for these items? I think its a 1965 version.
Trigi
- Ry, Denmark
- Posts 21
Hi Chris.
What is damaged? Some pictures would be nice.
Peter, DK
Agent00soul
- Joined on 11-10-2010
- Solna, Sweden
- Posts 61
I just won a curry Beolit 600 for 42 euro. It has a boken antenna but looks in good condition otherwise. I bought it for the curry panels and for spares because my black Beolit 600 has a slightly damaged bottom plate (broken plastic foot). Maybe I will try to restore both units if I can find a spare antenna. Are these available?
Trigi
- Ry, Denmark
- Posts 21
Hi Agent.
I gues u are talking about an 1970 beolit.. Silver frame?
I migth be able to help u out whit an atenna and perhaps some "Footwork"
Best regards
Peter, DK.
Agent00soul
- Solna, Sweden
- Posts 61
Trigi:
Yes, it's the 1970's model. It seems the frame is actually curry-coloured. I'll give a report when I have received it from the seller and have assessed the exact condition. Thanks in advance for your offer.
/Jörgen
Chris
- Posts 195
Agent00soul
- Solna, Sweden
- Posts 61
Now I have received the curry radio and done some cleaning. The only really broken parts are the antenna and one of the supports for the ferrite bar. The bottom plate is OK but the retaining pegs for it are missing. On my black radio the plastic foot in one end is damaged. This is riveted to the bottom plate so maybe the entire bottom plate needs replacing. One of the pegs for the bottom plate is missing too.
My original idea was to make one perfect radio out of the two but if the broken and missing parts can be replaced, both radios could be restored. Here are some pictures of the pair (the curry radio partly disassembled):
Medogsfat
- Posts 4,045
Chris:
I'm pretty sure these panel inserts can be removed & exchanged - the problem will be finding one if yours cannot be repaired.
As you can imagine parts for these have been unavailable for quite some time now.
Chris.
ipaul
- Joined on 04-22-2007
- Posts 378
Just fyi (if you didn't know already): the (telescopic FM-) antenna on your black one isn't the original one, at least not the top end...
Agent00soul
- Solna, Sweden
- Posts 61
Yeah, I suspected that. I have seen the ad from the guy who sells new ones. I'll probably order one from him. But I also need a complete antenna for the curry radio.
Page 1 of 1 (13 items)
