Latest post 03-31-2011 7:53 AM by akoro. 5 replies.
Page 1 of 1 (6 items)
  • 03-29-2011 1:23 PM
    Beolab Penta line-in
    Hi guys,
    The Line-In on the Penta MK3's, is it possible to feed them from an Apple Airport Express? What about sound control (volume) and on/off?
    Thanks in advance!
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 03-30-2011 9:49 AM In reply to
    • akoro
    • Top 500 Contributor
    • Joined on 08-07-2008
    • Espoo, Finland
    • Posts 88
    • Gold Member
    Re: Beolab Penta line-in
    Been there - done that.
    1. Yes it is possible.
    2. On/off will be automatic
    3. It really easy to pump up the jam to the maximum and scare the whole neighbourhood. I did it with Finnish artist Kirka by accident Ick!
  • 03-30-2011 10:20 AM In reply to
    On which device did you change the volume?
  • 03-30-2011 2:12 PM In reply to
    akoro:
    Thanks Akoro.
    I asked you this as I remembered earlier, but that was regarding BL8000. Wasn't sure it was possible on these.
    Thanks!
    So I better keep the "feeding" volume low then?
    -Andreas
  • 03-31-2011 7:49 AM In reply to
    • akoro
    • Espoo, Finland
    • Posts 88
    • Gold Member
    pacificocean:
    Volume is controlled from: iTunes, iPhone, iPad or iPod. Basically from that unit/player where you are sending the audio to AirPort. I used iTunes from iMac and there it is really easy to forget the volume to maximum - there was some computer speakers connected and for that reason the volume was turned up. Then I selected AirPort as device where to send the music and BOOM it went on.
  • 03-31-2011 7:53 AM In reply to
    • akoro
    • Espoo, Finland
    • Posts 88
    • Gold Member
    bayerische:
    akoro:
    Thanks Akoro.
    Thanks!
    I know that some dealers can provide you with cables that have 10dB attentuation. That helps the situation a lot.
