        1st March February 2012
	    Latest post 03-31-2011 7:53 AM by  akoro. 5 replies.
								        03-29-2011 1:23 PM
									        bayerische
								                - Joined on 12-11-2007
								                - Helsinki, Finland
								                - Posts 3,593
										    Hi guys,
The Line-In on the Penta MK3's, is it possible to feed them from an Apple Airport Express? What about sound control (volume) and on/off?
Thanks in advance!
									    -Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
									        akoro
								                - Joined on 08-07-2008
								                - Espoo, Finland
								                - Posts 88
										    Been there - done that.
1. Yes it is possible.
2. On/off will be automatic
3. It really easy to pump up the jam to the maximum and scare the whole neighbourhood. I did it with Finnish artist Kirka by accident
									        bayerische
								                - Helsinki, Finland
								                - Posts 3,593
										      akoro:
Thanks Akoro.
I asked you this as I remembered earlier, but that was regarding BL8000. Wasn't sure it was possible on these.
Thanks!
So I better keep the "feeding" volume low then?
									    -Andreas
									        akoro
								                - Espoo, Finland
								                - Posts 88
										      pacificocean:
On which device did you change the volume?
Volume is controlled from: iTunes, iPhone, iPad or iPod. Basically from that unit/player where you are sending the audio to AirPort. I used iTunes from iMac and there it is really easy to forget the volume to maximum - there was some computer speakers connected and for that reason the volume was turned up. Then I selected AirPort as device where to send the music and BOOM it went on.
									        akoro
								                - Espoo, Finland
								                - Posts 88
										      bayerische:
  akoro:
Thanks Akoro.
Thanks!
I know that some dealers can provide you with cables that have 10dB attentuation. That helps the situation a lot.
        Page 1 of 1 (6 items)
