I will try to help you, but I need some more information:
What version are your Tool?
Does this happen each time you download and you have liftet and repositioned your remote?
How big is your configuration? You can see some details when you are finalizing...
Are you using a Beo5 as suggested in subject or are you using a Beo6? The transfer method is different...
