Latest post 05-03-2011 5:06 AM by guffas. 28 replies.
Page 1 of 2 (29 items) 1 2 Next >
  • 03-24-2011 3:35 AM
    • Silou
    • Top 500 Contributor
    • Joined on 08-10-2007
    • Switzerland
    • Posts 241
    • Gold Member
    BEO5 write timeout
    Did you already have the "write timeout" message?
    It's a new message for me, because I use the same software, the same Pc and the same cables...
    What to do???
    thanks
  • 03-24-2011 4:02 AM In reply to
    Re: BEO5 write timeout
    I will try to help you, but I need some more information:
    What version are your Tool?
    Does this happen each time you download and you have liftet and repositioned your remote?
    How big is your configuration? You can see some details when you are finalizing...
    Are you using a Beo5 as suggested in subject or are you using a Beo6? The transfer method is different...
  • 03-24-2011 10:54 AM In reply to
    • OKF
    • Joined on 02-22-2008
    • Posts 204
    The transfer is different on those?
    Best regards Oliver
  • 03-24-2011 3:53 PM In reply to
    • Silou
    • Switzerland
    • Posts 241
    • Gold Member
    Hello Guffas,
    Thank's for your help.
    guffas:
     3.59
    guffas:
    Yes many times (the arrows on the top bar are white)
    guffas:
    Serialization started ...
    Parsing beo 4 config ...
    Beo 4 configuration parsed. Nr of buttons =476. Time elapsed (ms) =862
    Parsing beo 5 config ...
    Beo 5 configuration parsed. Nr of buttons =527. Time elapsed (ms) =3084
     Checking buttons ...
    Serializing configuration ...
    Configuration serialized.
       Nr of bytes serialized = 353292, (~345 Kbytes).
       Time elapsed (ms) =141
    Creating the configuration file ...
    Configuration file created!
       Time elapsed (ms) =691
    Serialization done.
     Total elapsed time(ms) = 5008 (~5.008 s )
    SAVED
    Thanks in advance
    • Silou
    • Switzerland
    • Posts 241
    • Gold Member
    oups I forgot one:
    It's a BEO5
  • 03-25-2011 7:18 AM In reply to
    If i remember right, I allso have problem with 3.59
    With 4.11 i dont have this problem.
    Get the version 4.11 and you are over that problem :-)
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 03-25-2011 10:27 AM In reply to
    I agree, try to find the 4.11 version somewhere.
    You configuration is not to big,  345 Kbytes is less than 2 Mega bytes.
    It is important that your USB wire between the computer and the Beo5 is not to long. It is possible to get a very short adaptor from Normal USB to mini USB.
    You can also try to use an USB hub between the computer and the Beo5. Some USB controllers are not working well with the Beo5.
  • 03-25-2011 7:30 PM In reply to
    • OKF
    • Posts 204
    Yes I agree. Since I have converted my B5 to B6 when I upload the software to the B6 it tells me that it is connected to a USB device but still updates the software. Also when I work on the software my WIFI goes and I need to restart if Iwant to use it.
    What difference does a hub make? WHich USB Version is the Beo5/6? Is it 1.1?
    Best regards Oliver
  • 03-28-2011 2:31 AM In reply to
    I think the USB version is 1.1
    A USB hub is a device that expands a single USB port into several so that there are more ports available to connect devices to a host system.
    http://en.wikipedia.org/wiki/USB_hub
  • 03-28-2011 2:55 AM In reply to
    • Silou
    • Switzerland
    • Posts 241
    • Gold Member
    Everything is ok with V 4.11.
    Again a BEO bug...  Whistle
  • 03-28-2011 6:18 AM In reply to
    • OKF
    • Posts 204
    I know what a USB Hub is the question was what difference it makes to use it?
    Best regards Oliver
  • 03-29-2011 2:13 AM In reply to
    Sorry for the misunderstanding...Embarrassed
    From practice I have seen a computer with it's own USB connector not able to register with a Beo5, was able to do it when I used a Hub between them.
    I guess that the Hub makes some kind of changes to voltage levels or timing.
  • 03-29-2011 5:41 AM In reply to
    • OKF
    • Posts 204
    okay, now I got you. Alright that is a good hint I will try that and feedback here, because I have the problem that the USB deregisters when I upload although upload works. Still I will try this because I should have an old HUB somewhere. Maybe it is an electrical issue.
    Best regards Oliver
  • 03-29-2011 6:01 AM In reply to
    If you have a Beo6, this will give you the "balloons" with error messages during the upload. The upload is handled differently from Beo5 and uses some kind of bootloader. The message appear when the Beo6 reboot after flashing.
  • 03-29-2011 6:05 AM In reply to
    • OKF
    • Posts 204
    yes prior to the figures counting up or respectivley down the USB has several error messages. But what does yor second sentence mean?
    Best regards Oliver
  • 03-29-2011 7:35 AM In reply to
    That, if you see the message 'USB Device Not Recogniced' in a balloon message (in the area at the clock) then it is normal.
  • 03-29-2011 7:39 AM In reply to
    • OKF
    • Posts 204
    yes that is what I see and you think a hub does not make a difference?
    Best regards Oliver
  • 03-29-2011 8:33 AM In reply to
    No, the Hub will not make a difference in this case. Only if you have initial problems with the connection.
  • 05-02-2011 5:04 AM In reply to
    Whenever I apply a config file to my Beo6 using Configuration Software 4.11 I receive the 'USB Device Not Recognised' message in the ballon whilst the Beo6 appears to power down and power back up as part of the 'configuration download' process. Whilst the configuration file appears to have been applied successfully on usage I find that several of the physical 'hard buttons' on the Beo6 don't respond - presumably due to the time out?  Is anyone else experiencing this difficulty or is there a way to avoid the issue?
    I can apply the same configuration file to my Beo5 using the same config file, same config tool on the same PC without the 'USB Device Not Recognised' message.
    Any help that could be provided here would be greatly appreciated.
    Many Thanks
    Graham
  • 05-02-2011 7:59 AM In reply to
    • OKF
    • Posts 204
    as described in this thread that is normal behaviour but the data get transfered. Maybe you try again.
    Best regards Oliver
  • 05-02-2011 10:33 AM In reply to
    Hi Oliver, thanks for the swift response.  I have reapplied the file several times.  I never receive an error message in the configuration tool itself the configuration software appears to be applied successfully.  Unfortunatley I always see the 'USB device not regonised' bubble in Windows and find that the usage of the 'standby', 'fast forward' and other physical keys are not usable on the Beo6.
  • 05-02-2011 10:43 AM In reply to
    • OKF
    • Posts 204
    I have exactly the same but everything gets programmed  propperly. Is these standard commands created by the software or your own buttoms?
    Best regards Oliver
  • 05-02-2011 12:36 PM In reply to
    yes - these are the standard commands created by the software - they are the physical buttons on the device and the issue is consistent no matter what is selected.
  • 05-02-2011 1:02 PM In reply to
    • OKF
    • Posts 204
    that is the hardware then, and that you cannot be programed, the hardware will be broken, can you for example turn volume up and down with the turning wheel? that is the hardware as well.
    Best regards Oliver
  • 05-02-2011 1:04 PM In reply to
    Hi, yes the wheel works fine.  The issue is confined to the standby, fast forward, stop and right keys only.
